Old 10-12-2016, 10:47 PM   #1
secaworks
Drives: 2015 Subaru BRZ
2013 Subaru BRZ Limited with 6.6l LS2 V8
-2013 Subaru BRZ limited in dark grey metallic with only 3001 miles on the car and 2000 miles on the motor.
-Asking price is $31,999.
-LS2 6.6 liter Texas Speed stroker kit built top and bottom end tied in nicely with a WGP cross member recently reinforced and re-welded for rigidity.
-Car was built by Weapons Grade Performance and refined by my crew at Supreme Ford in Laplace, LA.
-WCCH ported 243 heads topped with Comp gold upgraded rocker arms and appropriate valves/springs.
-T56 6 speed trans with ZL1 clutch setup and drive by wire throttle setup. Upgraded trans mount and bushings with fresh new fluid.
-New Z06 motor mounts and brackets. Racepro ¼ quart catch can.
-Fast 90 intake manifold
-Tuned with hp tuners
-Cusco front strut brace, Cusco rear adjustable control arms, and Cusco differential brace.
-Lexus rear end with a 3.55 rear end gear. Sikky aluminum driveshaft recently re balanced.
-KW variant 3 fully adjustable coil overs.
-Front and rear Stoptech brake kit
-Enkei Raijin 18x8.5 front, 18x9.5 rear with Bridgestone Potenzas 245 front/285 rear.
-Vehicle has had all fluids changed and oil change twice already with Castrol 5w30 full synthetic, royal purple trans fluid, dex-cool coolant with royal purple additive, and BG rear end fluid.
Vehicle has new LED side markers, LED turn signals, LED interior lights, and also custom gauge pod with oil pressure and wideband air fuel inside cluster enclosure with odo/trip buttons relocated to trunk pop position. Louvers were cut in the hood to aid with heat dissipation.
***no a/c, all HVAC controls and compressor are in but I do not have the evaporator in or the lines due to trying to find somebody to create a hi pressure line from the Subaru line(which is included with the car) to the GM compressor***.
The car has all factory functions including navigation working except for trunk pop, and cruise control due to can bus network issues between the Subaru PCM and GM ECM. The vehicle has been thoroughly gone through with several fine tooth combs. All fasteners checked and re-torqued or changed if deemed not correct for the application, new radiator hoses, wiring for drive by wire and fan wiring have all been addressed and repaired/replaced. This is not a daily driver car, it is extremely light weight and nimble and extremely fun to drive. Please serious buyers only the car is located in Laplace, Louisiana at my shop right now and any serious buyers are welcomed to come by.
secaworks is offline
Old 10-18-2016, 12:12 AM   #2
secaworks
Bump.
Old 10-18-2016, 12:26 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This is how you do this car!
hmong337 is offline
Old 10-18-2016, 04:06 PM   #4
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
sweet jesus
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 10-20-2016, 08:06 PM   #5
Statefan313
Drives: 1991 BRG Miata,2013 fiat 500 Abarth
Still for sale?!
Statefan313 is offline
Old 10-26-2016, 06:20 PM   #6
Reign03
Drives: Car
Amazing. Free bump. What kind of power is this making? Do you have any video?
Reign03 is offline
Old 10-27-2016, 12:34 AM   #7
Jyoung1996
That's sick. Write a post if your at a car meet or anything around Baton Rouge I'd like to see it in person
Jyoung1996 is offline
Old 10-28-2016, 08:27 PM   #8
secaworks
The engine builder claimed 532 whp 586wtq but I do not have dyno sheets to confirm. You can google "BRZ06" and see lots of write ups on the car. They have a video of it on the dyno for tuning:
[ame]http://youtu.be/puErFrsmM5E[/ame]
Old 10-28-2016, 08:27 PM   #9
secaworks
Sale fell through so the car is back on the market!
Old 10-29-2016, 08:41 PM   #10
tgarr
Drives: wishful thinking
Very interested..sent you a pm.
tgarr is offline
Old 10-29-2016, 10:22 PM   #11
Kensu
Drives: 13 brz premium
car originally from CT? its where im from. would have loved to see this beauty.
Kensu is offline
Old 11-01-2016, 01:24 AM   #12
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
Hmm... PM'd.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline
Old 11-01-2016, 10:36 PM   #13
ILLSMOQ
Drives: 2017 WR BLUE BRZ
How is the car not sold already at that price?
ILLSMOQ is offline
Old 11-10-2016, 08:28 AM   #14
kcam86
Drives: Asphalt FR-S MT
Odd question but does the abs and traction ctrl still work?
kcam86 is offline
FS: 2013 Subaru BRZ Limited asnyder1997 Cars for Sale/Trade 2 04-20-2015 10:40 PM
2013 Subaru BRZ limited - $13,500 financialguy Cars for Sale/Trade 0 02-22-2015 08:45 PM
WTS: 2013 Subaru BRZ Limited $22,000 smmmurf Cars for Sale/Trade 10 12-09-2013 03:19 PM
WTS: 2013 Subaru BRZ Limited $22,000 smmmurf Northern California 13 12-09-2013 03:18 PM
2013 Subaru BRZ Limited 6MT phiberoptik BRZ First-Gen (2012+) — General Topics 51 09-13-2013 12:37 PM
