Old 10-10-2016, 06:26 PM   #1
scubie.brz
Drives: hyper blue BRZ
Is my alignment good?
I recently got an alignment with camber bolts after mounting my wheels (wedssport tc105n 17x9 +35 with bridgestone potenzas re71r 245 40 17) i managed to get 2.2 camber with just the camber bolts is that good?
Sent from my HTC One_M8 using Tapatalk
scubie.brz is offline   Reply With Quote
Old 10-10-2016, 06:28 PM   #2
scubie.brz
I plan on tracking the car soon and autoX but for now I just go on a lot of mountain roads is this alignment up to par for my needs?
Old 10-10-2016, 06:37 PM   #3
frslee
Just drive it
Drives: 13' FR-S
nice
frslee is offline   Reply With Quote
Old 10-11-2016, 04:18 AM   #4
benzz280
Drives: Toyota 86
What kind of camber bolts give u that much camber up front? or do u have camber plates too? Am using spc/whiteline camber bolts installed on top strut holes and only got -1.2 degree max
benzz280 is offline   Reply With Quote
Old 10-11-2016, 04:21 AM   #5
scubie.brz
Spc camber bolts
Old 10-11-2016, 05:15 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What spring rates and tyres are you using?
Old 10-11-2016, 05:22 AM   #7
scubie.brz
Stock springs potenza re71r ,245
Old 10-11-2016, 06:30 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I got -2.2(-2.4 if aligned with me sitting in) in front with SPC 81305/Whiteline KCA416 camber bolts in both holes with stock coilovers. Seems about the same as for OP. Rather "only 1.2" seems a bit too little.
Old 10-11-2016, 07:03 AM   #9
Captain Snooze
Drives: Red Herring
Ok. Remember this: everything's a compromise.
I am thinking you are going to have "too much" grip on stock springs with those tyres with that width. If/when you go to the track I'm thinking you will be riding on the bump stops a fair bit. I am suggesting you want as much camber as you are willing to go.
I use 225 sticky tyres with 6k/6k (I was on 9k/10k) springs and run front camber -3.2 and rear camber -2.7 . Ideally you would be using a pyrometer to set your camber.
Because compromise.
I just noticed you had your tyres mentioned in your first post. Whoops. Forum blindness.
Old 10-11-2016, 06:58 PM   #10
strat61caster
strat61caster's Avatar
I'd be a bit wary of the handwritten numbers but other than that it looks like a good compromise to start driving hard. Focus more on seat time than tinkering.
ineedyourdiddly
Old 10-11-2016, 11:44 PM   #11
benzz280
Drives: Toyota 86
Both holes meaning top and bottom strut holes?
Old 10-12-2016, 02:37 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Yes. But guessing that similar can be got with relocating/reusing from bottom strut hole to top one stock 14mm OE crash bolts (not excentric, just using fact that top hole is 16mm), and getting just SPC excentric crash bolts for bottom ones, if budget is tighter.
Old 10-12-2016, 01:48 PM   #13
benzz280
Drives: Toyota 86
I didnt know u can use the spc camber bolts on the bottom strut holes cos their instructions said to use them on the top holes only
Old 10-12-2016, 02:15 PM   #14
strat61caster
There's different sizes for the top and bottom hole. The top bolt is too large for the bottom hole.
ineedyourdiddly
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 04:44 AM
Anyone know a good alignment shop around inland empire? azynneo Southern California 10 11-05-2015 03:38 AM
Looking for a good alignment shop in southern Maryland Qadthane Mid-Atlantic 3 03-18-2015 08:40 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 10:53 PM
Good alignment shop in Federal Way? JRP Northwest 8 11-23-2014 02:18 AM
