Old 10-09-2016, 11:35 PM   #1
ThisGuyRett
This Guy
ThisGuyRett's Avatar
Drives: 2015 Halo FR-S M/T
Strange Smell after Driving
Hello all,
I have 6mt 2015 FRS with about 19k miles on the odo.
After driving for periods of 30mins or longer, i get this strange smell coming from the engine bay. It is not the clutch. I know what burnt clutch smells like. This smell is more of a "hot burnt plastic/rubber" smell. No issues with my camplate.
This smell makes me question my driving ability with the manual transmission, but I have been driving manual for years. I have owned this FRS for about 3 months now and I want to know if this normal or not. Thanks in advanced guys.
P.S. - I have done a ton of research but I have only found threads on the earlier production models and they were new.
Photo for attention
ThisGuyRett is offline   Reply With Quote
Old 10-09-2016, 11:47 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Is it strong chemically? May be engine cleaner. I took to dealer, they spilled oil, used degreaser/cleaner and 2k miles later smell didnt go away, so I just sprayed my engine bay down twice. Went away after 20min of driving.
Old 10-10-2016, 12:19 AM   #3
Originally Posted by ThisGuyRett View Post
Hello all,
After driving for periods of 30mins or longer, i get this strange smell coming from the engine bay. ...........
Great picture!
Is that smell normal ?...... well, my FR-S doesn't smell that way.
Does your car have any power mods ..??
So, you have ruled out a possible leaking cam plate .......hmmmm ...... what about the timing chain cover or oil dip stick "O" ring leaking down onto the exhaust heat shield ..??
You might feel your front wheels after driving for a spell, to make sure you don't have a front brake pad dragging... ??
Old 10-10-2016, 07:55 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
start your search around the exhaust header, it's the hottest part of the engine compartment, it could be something that got int there off the road or a fluid.
guybo is offline   Reply With Quote
Old 10-10-2016, 10:07 AM   #5
ThisGuyRett
This Guy
It's not a chemically smell. Hadn't done any oil changes yet, but I've smelled this smell ever since I bought the car. Thanks for the info
Sent from my SM-N920V using Tapatalk
Old 10-10-2016, 10:17 AM   #6
FX86
you doing burnouts and powersliding your car around too much?
Old 10-10-2016, 10:21 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
You're mistaken, he's not driving a muscle car....it's a Twin.
Old 10-10-2016, 10:30 AM   #8
FX86
how do you know he doesn't secretly own a mustang?
The Following User Says Thank You to FX86 For This Useful Post:
JD001 (10-10-2016)
Old 10-10-2016, 10:31 AM   #9
ThisGuyRett
This Guy
Great picture!
I had the dipstick gasket replaced when I first bought the car and had white smoke coming out of it. There is no visible oil leaks anywhere. I had it on a lift over the weekend changing the transmission and diff fluid.
As for the front brakes, there is no dragging from what I can see. I'll check next time I drive if the smell is stronger around the brake area.
The Following User Says Thank You to ThisGuyRett For This Useful Post:
humfrz (10-10-2016)
Old 10-10-2016, 10:33 AM   #10
ThisGuyRett
This Guy
No visible spots or fluid on the exhaust header. Did have a leaky dipstick once but that has been resolved a while ago. Thanks for the input!
Old 10-10-2016, 10:50 AM   #11
radroach
Drives: car
@ThisGuyRett Even if there's no visible spots on the header, check for oil leakage under the passenger side engine timing cover, use a paper towel and swipe on the underside, it's an angled piece that sticks out a a bit.
Old 10-10-2016, 11:01 AM   #12
Rezi
Drives: GT86
Maybe the green wax they put on the engine bay when shipping oversea?
Rezi is offline   Reply With Quote
Old 10-10-2016, 11:04 AM   #13
ThisGuyRett
This Guy
I'm not doing it enough lol. I've done it once or twice since ownership but only when it's wet out.
Old 10-10-2016, 11:05 AM   #14
ThisGuyRett
This Guy
No mustang. Lol I uphold public safety, not endanger them. :p
JD001 (10-10-2016)
Nightmare driving FR-S vs driving Miata chrisngn FR-S / BRZ vs.... 64 07-06-2016 11:21 AM
Does anyone else occasionally smell a burning odor during cold weather driving? Meanderchap Scion FR-S / Toyota 86 GT86 General Forum 21 01-10-2016 02:10 AM
2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while hosfordbrandon Issues | Warranty | Recalls / TSB 46 11-02-2015 02:42 AM
Anyone else notice a strange smell?? Bigedb Scion FR-S / Toyota 86 GT86 General Forum 13 07-19-2013 12:43 AM
strange smell - kerosine karlos13 AUSTRALIA 7 08-20-2012 12:50 AM
