Old 10-06-2016, 03:50 PM   #1
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Suspension Issues
- Fortune Auto 500 Coilovers using 8k Swift springs on radial bearings in the front. 20 clicks.
- Fortune Auto 500 Coilovers using 6k Swift springs in the rear. 17 clicks.
- Whiteline 20mm adjustable front sway bar.
- Whiteline 18mm adjustable rear sway bar.
- Enkei RPF1 18x9.5 wheels.
- Hankook Ventus V12 Evo 2 245/35/18 tires.
The suspension was fairly dialed in on stock wheels. It still needed some work. I thought about getting stiffer springs. A shop installed RPF1 wheels + 245 tires recently. My suspension is now totally out of whack. ( T _ T ) All Aspects Motorsports will work on it soon. I was hoping to run a NASA HPDE1 this month. Any suggestions for further enhancements? :/ I will continue diving through the forums.
Fenix is offline   Reply With Quote
Old 10-06-2016, 03:54 PM   #2
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
What exactly does "out of whack" mean?
Toyarzee is offline   Reply With Quote
Old 10-06-2016, 03:55 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I assume the wheels were balanced with the install? Maybe it needs an alignment.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-06-2016, 03:55 PM   #4
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
"totally out of whack" is not a useful description of the problem. (If you want suggestions for how to get the susspension "in whack")
Twinz is offline   Reply With Quote
Old 10-06-2016, 04:05 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Abbreviation for Wheels Have Actually Coincided with a Kerb.
Old 10-06-2016, 04:15 PM   #6
Fenix
Fenix's Avatar
Yes, it does. It pulls left, steering feels loose, knocking/clunking/squeaking noises, bounce, tires rubbing at full lock... I will continue to add and refine details as I recall them. Too bad none of you are local. :/
Sent from my Nexus 6P
Old 10-06-2016, 04:17 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
What size offset are the wheels? Sounds like the ET is too low and you're having rubbing issues.
Current DD: M235i
Old 10-06-2016, 04:39 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
First things first.
Did you properly preload the coilovers?
Did you corner balance yet?
Old 10-06-2016, 04:49 PM   #9
Toyarzee
Shibby!
Toyarzee's Avatar
Corner balance a bit excessive... At minimum a traditional alignment is likely necessary. Also, how low are you?
I'm betting alignment was possibly shit beforehand and it was accentuated with the increase in contact patch.
When were coilovers installed, by whom, and was it aligned afterward?
Don't worry this sounds minor and you can run your race if you get this squared away soon
Old 10-06-2016, 06:48 PM   #10
Fenix
Fenix's Avatar
+38
I highly doubt this is causing issues. :/
Originally Posted by x808drifter View Post
First things first.
All Aspects Motorsports adjusted everything on stock wheels. I would assume they did preload them. I chose not to corner balance my car. They are capable of doing so if wanted.
My car height is shown in this picture:
I started installing components myself. All Aspects Motorsports finished it about a month later. lol Long work hours, bad weather, lack of space and inexperience made what should have been a quick install into total frustration.
An alignment was never done by Professional Rim Repair on the receipt. I should have looked sooner. 'facepalm' I prefer All Aspects Motorsports or RaceWerks do an alignment instead. I tend to hyperbole minor issues. ¯\_(ツ)_/¯
I am thinking about additional suspension upgrades before touching the gearbox or engine. Aaron from All Aspects Motorsports has basically told me there is no need for additional upgrades except maybe FI until I have plenty of hours under my belt.
Old 10-06-2016, 07:07 PM   #11
swarb
Suggestion for good brake pads and brake fluid and track spec alignment.
Old 10-06-2016, 07:14 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I find your spring rates odd? I have 7k front and 8k rear if I remember right. You want more spring in the rear IMO to help balance the car as you have to account for motion ratios.
Old 10-06-2016, 07:16 PM   #13
Fenix
Fenix's Avatar
Motul RBF600 brake fluid + Hawk HP Plus brake pads on blank rotors.
Old 10-06-2016, 07:21 PM   #14
Fenix
Fenix's Avatar
Here is a past e-mail from Matt at Fortune Auto:
Originally Posted by Matt @ Fortune Auto
Branden,
Honestly the FT86 chassis is one that like a stiff front and soft rear to keep wheels on the ground. I myself like 8k front 6k rear in swift spring. for street/track use. larger front sway and stock rear bar. I run the shocks up around 12 clicks on the front, 5 in the rear for street use and full stiff in the front and 12-15 clicks in the rear for track use.
Regards,
Matt
FS: Custom Bilstein suspension/coilovers Kostamojen Brakes, Suspension, Chassis 11 11-21-2016 03:21 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
