Old 10-05-2016, 03:34 PM   #1
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
2017 Aluminum Manifold F/I
So has anyone picked one up to try? I guess the runners are slightly different so should flow better then the plastic ones. Thoughts?
Gearbanger is offline   Reply With Quote
Old 10-05-2016, 03:38 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I doubt it makes any difference when you are forcing air into the engine with a SC/turbo. Being metal I assume it heat soaks fairly quick
Old 10-05-2016, 04:34 PM   #3
Gearbanger
Gearbanger's Avatar
Someone threw up a dyno I assume on a na car showing 1hp gain but loss of 1 torque.
Old 10-05-2016, 08:17 PM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I got 1 on order, ill let you know. Ill pressed plastic junk doesnt hold up to heat and pressure long term. Plus its STI red and 1/3 of aftermarket.
http://www.ft86club.com/forums/showthread.php?t=110920
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-05-2016, 10:02 PM   #5
Gearbanger
Gearbanger's Avatar
Cool very interested in the outcome.
Old 10-05-2016, 10:13 PM   #6
VitViper
Drives: '15 FRS
It's not going to make a cent worth of a difference. I'm putting 23psi+ into the stock plastic one (and I'm sure others are doing more) and it's holding up fine.
VitViper is offline   Reply With Quote
Old 10-05-2016, 10:58 PM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just throw a positive displacement supercharger on!
MS, CSCS, TSAC-F, CPT
Old 10-25-2016, 10:54 AM   #8
Gearbanger
Gearbanger's Avatar
Bump for any updates on these.
Old 10-25-2016, 11:32 AM   #9
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We have tested this, see our facebook page, should be not too far down.
https://www.facebook.com/motoeast/
https://www.facebook.com/motoeast/po...07288429318735
It makes for more power up top, we tested it the same boost level before and after, with zero tuning changes. Likely with tuning you can open it up a bit more as well.
Xero-Limit is offline   Reply With Quote
Old 10-25-2016, 04:41 PM   #10
Gearbanger
Gearbanger's Avatar
NIce gains Im only pushing 11.5 PSI so maybe 10 whp gain still not bad.
Old 10-25-2016, 06:22 PM   #11
GsxrMe
GsxrMe's Avatar
Very Very nice find. I have my 2017 intake already but decided to wait to install it until I have my short block and my return style fuel system installed. The Walbro 485 Fuel Pump has been fantastic and I don't wait to push the limits of the factory toilet paper rods at the cost of a cracked block.
The Manual Transmission 2017 intake should of been there since the beginning of the Subaru BRZ, I know some people love the auto's but that option should be only offered by Toyota.
Thank you Subaru for stepping up!
2014 Subaru BRZ
Old 11-14-2016, 05:56 PM   #12
Gearbanger
Gearbanger's Avatar
Found this with regard to the Crawford Power blocks wouldn't this apply also to a full aluminum manifold vs plastic? So is the gain a "dyno" only gain ie real world hood down driving would cause heat soak and higher IAT?
Kodename47 has it right on the money, except for the fact that we actually found the billet power blocks to cause a fair to large amount of heat soak. We tested an NA car with them and the car physically lost power every single pull with the blocks on. We took the blocks off, adjusted and then did repeated pulls again, in which the car was consistent in power every time. We believe this to be due to their choice in material. The factory definitely chose plastic for the intake manifold material for a good reason, and that's not limited to cost.
2017 Red Manifold BrunoCr7 Engine, Exhaust, Transmission 121 03-26-2018 01:35 PM
BRZ 2017 Aluminum intake! MT6 GsxrMe Forced Induction 27 07-23-2017 12:17 AM
Controlling the nannies in 2017 vs. pre 2017 mdm Scion FR-S / Toyota 86 GT86 General Forum 23 10-04-2016 11:11 PM
OEM manifold BarryPanick Engine, Exhaust, Bolt-Ons 1 03-16-2016 07:23 PM
OEM manifold Reaper Engine, Exhaust, Bolt-Ons 1 06-24-2014 11:46 PM
