Drives: Late 2014 Subaru BRZ
BRZ 2017 Aluminum intake! MT6
So Subaru killed the plastic intake for a real aluminum intake for the 201MT6 only. I've been eye balling FBM intake for a year now to add to my motorbuild but Subi has really brought us MT guys an aluminum factory. I can see the factory plastic intake is pressed together and time will kill it sooner than later. MAP location is directly in front of the TB.
Subi knows MT6 guys are boosting? Any thoughts? Go...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Drives: 2014 BRZ
Cool! Wonder the reason for the battery relocation.
| The Following User Says Thank You to Amputechture For This Useful Post: | Traktor (12-26-2016) |
Drives: JDL Turbo BRZ
The pic shows a RHD car. It gets swapped with the brake booster too. Last edited by Jesse36m3; 09-23-2016 at 03:35 PM. |
| The Following 3 Users Say Thank You to Jesse36m3 For This Useful Post: |
Drives: 2014 BRZ
Stupid me. Interested to see if there is anything to be squeezed out of these. I know Velox didn't have much luck with their prototype manifolds. MAP sensor has to be rescaled I'm assuming?
Not Bаnned Anymore
Drives: Heavily Modified FRS
Depending on the cost I want one for my '13 but I would have to paint it black. I think the red looks awful lol
#6 | |
MAP is pressure sensor MAF is air flow, its in same location will be ok |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Boofneenee (10-26-2016), Guff (09-24-2016) |
Drives: 2014 BRZ
#8 | |
MAP sensor calibration in tune is just two numbers an offset and a pressure/volt . like bar/volt .833 offset (bar) .012 where the MAF you actually scale the sensor volts against air flow at a large number of points |
| The Following User Says Thank You to steve99 For This Useful Post: | JohnJuan (09-23-2016) |
Drives: Subaru BRZ
#10 |
Drives: 2014 BRZ
I know these are so new to market but has anyone been able to tinker with these yet? Zach or Drift office Bob maybe? : )
#11 |
I got the local subi dealer have 1 on order for me. 3 to 4 weeks. Just over $300.
2014 Subaru BRZ
| The Following User Says Thank You to GsxrMe For This Useful Post: | FRS_Ken (12-05-2016) |
#13 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Wouldn't this retain more heat than the plastic intake manifold? Are there reported failures of the plastic intake manifolds?
#14 | |
Sarcastic SOB
Whether this is significant...well, Subaru does employ a lot of engineers so I doubt it in most applications. It is a nice STI looking intake though and certainly one of the added appeals of buying the newest model. The only negative I can think of with the plastic one is that some people might accidentally break off the clips on the intake cover when accessing the intake manifold inlet from the PCV while installing a catch can. I did, but made a little clip from stainless sheet metal and glued it in place of the broken clip.
| Tags |
| sales@delicioustuning.com |
| New Carbing Aluminum Air Intake Suction Kit | Pekingduck | Engine, Exhaust, Bolt-Ons | 11 | 11-28-2016 07:16 PM |
| FS: Lower control arm | ssyed | Canada Classifieds | 24 | 10-30-2016 06:13 PM |
| PRICE DROP New Fujitsubo Authorize-R Catback Exhaust & Carbing Aluminum Air Intake | Pekingduck | Engine, Exhaust, Bolt-Ons | 7 | 07-15-2016 06:30 PM |
| ?? about the 2017 changes. | UAmach1 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 03-28-2016 08:55 PM |
| GenomeTuning Aluminum Intake Plugs | genometuning | Engine, Exhaust, Bolt-Ons | 58 | 06-23-2014 07:43 PM |
