Old 10-04-2016, 11:41 PM   #1
k.houan
k.houan's Avatar
Drives: BRZZZ
Sadly..I'm considering trading in the BRZ. I need some advice though!
So after some thought, I am considering moving on to a car that can fit more than 2 people in it comfortably.
Not too sure what exactly still doing some research.
The problem is I'm not really sure if I should try to trade the BRZ in towards the new car,or sell the car privately and use the funds toward the new car.
I only have around $5k left to pay off.
Looking for some advice from someone with more experience than me in this situation
Which direction would benefit me the most?
Another thing, I could return the car to stock no problem if I was trading it to the dealer. The only problem I see is that the insides of my headlights are painted black, I dont see any decent way to reverse that. Does anyone know if they would even take the car with modified headlights?
Any input would be greatly appreciated.
k.houan is offline   Reply With Quote
Old 10-04-2016, 11:58 PM   #2
ryoma
ryoma's Avatar
I would say that you will get the most out of it by returning as much back to stock as possible and selling the car and parts privately. it might take a while to get everything sold, but it will most likely be worth more than a dealership will give as trade in value.
on the other hand, if the dealership gives you a trade in value that is only slightly lower than what you think you can sell the car for, then go for it if you don't want the hassle since you can instantly get rid of it instead of waiting for the right buyer.
either way, return as much back to stock as you can. and I doubt the dealership will care you painted your headlights as long as they work.
Old 10-05-2016, 12:48 AM   #3
k.houan
k.houan's Avatar
Drives: BRZZZ
Sounds like good advice. Are you sure about the dealer being ok with painted lights? Never seen a Subaru dealership sell any modded cars ever, could be my area though.
Can anyone else chime in?
Old 10-05-2016, 01:14 AM   #4
Brayden_23
Drives: Asphalt 2015 FRS
As long as the painted headlights don't affect the functionality of the headlight (i.e. reduce light output) then the dealership shouldn't have a problem accepting it.
Another route you could take is swapping headllights with another member. I'm sure there is quite a bit of people out there who would like a painted headlight but don't feel brave enough to tackle the job themselves..
Brayden_23 is offline   Reply With Quote
Old 10-05-2016, 03:35 AM   #5
wtfrs
Drives: 2014 Monogram
Check out carmax for trade in values if you do return it to stock, they give crazy values sometimes.
wtfrs is offline   Reply With Quote
The Following User Says Thank You to wtfrs For This Useful Post:
why? (10-08-2016)
Old 10-05-2016, 08:35 AM   #6
DarkSunrise
DarkSunrise's Avatar
In some states you get a tax credit on the new car from your trade-in. That (along with ease of transaction) can make it worth it to trade the car in even though the trade-in value may be slightly less than a private party sale value.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
g e (10-08-2016)
Old 10-05-2016, 08:49 AM   #7
jasonojordan
Drives: 2013 satin white brz limited
Even if the dealer was not ok with the painted lights worse they would do is dock you on what the car is worth because of it. They would do this because in their mind they would need to remove the lights and replace them with new ones so that they can resell it.
jasonojordan is offline   Reply With Quote
Old 10-05-2016, 09:25 AM   #8
15limited
15limited's Avatar
If you return to stock and your BRZ qualifies as certified pre-owned, iirc there's a mileage limit, that would give you some bargaining power and probably best trade in value.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-05-2016, 09:45 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Air force guy?
Anyways, yeah the dealer will take the vehicle with painted headlights. They don't care about modifications as long as the car is clean and doesn't have anything wrong they will generally go off auction value. For a limited with under 30K you should expect 17K or so in trade.
Being that your vehicle is almost paid off you could actually leverage that and maybe get a better trade value which would equal more equity for you and make the process easier. Sometimes it isn't worth the hassle trying to return to stock / sell privately. Depends on how long you have and how much effort you want to make for a 2-3K difference. These cars don't hold value very well unfortunately so its all dependent on condition and mileage. Mods don't add value either....
Old 10-05-2016, 09:51 AM   #10
jasonojordan
I was offered a year ago for my white limited with exhaust and some other mods left on the car and a front bumper that needed a respray 18k. The car had 30k miles. Area you are in does effect the price to so just kinda an idea of what you can expect I guess.
Old 10-05-2016, 10:23 AM   #11
perryair
junior mafia
Drives: ‘20 sti limited
*this* - if your net after payoff is 10k for example, thats 10k of your new car that you don't have to pay taxes on. most states allow it, couldnt find a recent list but as of 2011 the only municipalities that didnt allow it are:
California
District of Columbia
Hawaii
Kentucky
Maryland
Michigan
Montana
Virginia
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 10-05-2016, 12:44 PM   #12
SubieSyncro
SubieSyncro's Avatar
Drives: 1989 VW Vanagon Syncro
If it were me I would bring your car to a couple of dealers first to see what you are looking at for a trade in. You can then find out how they feel about any of the non-stock items. Test drive something fun that you might be getting to haul more people like a BMW 335i or a WRX. With that number in mind as a backup, you will better know how to price your car and what offer you might accept from a private buyer. Selling privately is a PIA, but unless you are losing sales tax credits as mentioned above, you stand to save $2-3 thousand on the exchange.
SubieSyncro is offline   Reply With Quote
The Following User Says Thank You to SubieSyncro For This Useful Post:
why? (10-08-2016)
Old 10-08-2016, 11:50 AM   #13
g e
Take it to Carmax and see how much they offer.
Do your homework first and get a range of values from KBB, Edmunds, autotrader etc
g e is offline   Reply With Quote
The Following User Says Thank You to g e For This Useful Post:
why? (10-08-2016)
Old 10-08-2016, 12:15 PM   #14
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
I was in a similar situation a month ago when going for a new STI -- same reasons as you, needed more room.
If you want another Subie and don't have any accidents, go back to stock and use the guarantee trade in program, it is absolutely killer.
If you're okay with having a period where you won't have a car between selling privately and getting new one then I'd suggest going that route.
But keep in mind if your state allows trade in to lower taxes, you may potentially be looking at an extra grand on top of trade in value.
At time of trade in I had aftermarket OP, FP, CBE, wintertires, and springs on it. Except for noticing the tips, they never mentioned, asked or noticed the rest.
In my situation, after trade-in value and tax credit, I estimate that a private sale would've netted me maybe $1K more 1.5K tops but I couldn't be without a car and it saved me the hassle so it was worth it to me.
But yeah go around to a couple of dealerships, make sure their appraiser is available and just get a benchmark. Literally takes like 20 minutes.
Good luck!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
The Following User Says Thank You to ray7792 For This Useful Post:
why? (10-08-2016)
Trading in my car!!! raven1231 Scion FR-S / Toyota 86 GT86 General Forum 103 02-27-2015 07:44 AM
Trading up to RC-F Monogram Scion FR-S / Toyota 86 GT86 General Forum 99 01-11-2015 03:08 PM
Advice for trading in FRS to dealer peachsnow Scion FR-S / Toyota 86 GT86 General Forum 65 11-25-2014 07:22 PM
Trading AT BRZ for MT BRZ cmagat Northern California 10 08-29-2014 12:27 AM
