Old 10-01-2016, 06:36 PM   #1
trex510
trex
Drives: brz
Red face brz wheels
what is a decent looking wheel for the brz that is preferably under 1k? becuz im on a budget
trex510 is offline   Reply With Quote
Old 10-01-2016, 06:38 PM   #2
swarb
http://www.ft86club.com/forums/showthread.php?t=7535
The Following 2 Users Say Thank You to swarb For This Useful Post:
funwheeldrive (10-11-2016), kch (10-03-2016)
Old 10-01-2016, 06:51 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
720 Forme GTF1. Light at approx 15 lbs in 17x8, maybe 16.5 lbs in 17x9. See them in my avatar. Similar strength and weight as Enkei RPF1 without the common design and (in my opinion) ugliness.
Old 10-04-2016, 01:48 AM   #4
trex510
trex
Drives: brz
thank you so much!!!! btw how much were the price of your tires for the set of wheels?
Old 10-04-2016, 01:50 AM   #5
trex510
trex
Drives: brz
and do you have a link for where you bought the GTF1?
Old 10-04-2016, 01:52 AM   #6
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
You could always go with Ambit wheels and use the TJ hunt discount code to get them at like 50$ a wheel
Xxyion is offline   Reply With Quote
Old 10-04-2016, 02:19 AM   #7
one2onejackpot
one2onejackpot's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
what is a decent looking wheel for the brz that is preferably under 1k? becuase im on a budget
Click on the link in my signature, My 2016 Subaru BRZ Series.HyperBlue Build. I went with Enkei GT7 Hyper Silver rims (also available in black.) They make the STI rims, but I wasn't planning on spending that much for those, although they look hot.
I don't really like to give out links, but check out tirerack.com. I'd go with a set of Enkei wheels you like and since your on a budget, probably go with the Dunlop Direzza DZ102 or Yokohama S.Drive tires since you live in California and they are in the Ultra High Performance Summer category. They both look good at channeling rain. The Yokohama tires would probably do a better job of it. And what ever you do, do not get them siped.
A bit of advice, try to use the TPMS sensors from your old rims, if possible. If you're going to be putting your original tires on the new rims you'll have no problems. Sometimes the aftermarket sensors don't want to program correctly because Toyota made the sensors to be programmed specifically to each wheel. Some shops know of ways around it, but the only way I know how to do it is to load up Toyota Techstream software on a Windows 7 computer (As far as I know, Toyota hasn't updated the software past Windows 7, there's a way to get it to work on 8 possibly 10, but you have to do a lot of fiddling around) and program each wheel with the correct sensor to each individual wheel. A Subaru dealer will have no idea they have to do this unless you tell them because Subaru Sensors don't have to be programmed this way. Also, a Toyota dealer will probably try to over charge you. I just bought 4 new Toyota sensors and programmed it in Techstream myself since I use snow tires on my factory rims. Otherwise, if your light pops on, just take it over to DiscountTire. I think they can do it for you on the cheap. If they are reusing your old tires, don't let them trick you into buying new sensors or rebuilding the old ones, have them use the old ones even though they'll try to say they may not work or some bs.
Here's a youtube link of a guy programing his on a Toyota Highlander.[ame="https://www.youtube.com/watch?v=jrR78PogYw8"]Replace Broken TPMS Sensor and Add New TPMS Sensor in Toyota Lexus or Scion w/ TechStream TIS - YouTube[/ame]
LOVE. It's what makes a Subaru, a Subaru.
Last edited by one2onejackpot; 02-07-2017 at 02:34 PM. Reason: Added TPMS Techstream programming video link
one2onejackpot is offline   Reply With Quote
The Following User Says Thank You to one2onejackpot For This Useful Post:
Imperius (02-07-2017)
Old 10-04-2016, 03:10 AM   #8
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
Really? With the discount its only $50 a wheel? Is this for all Ambit wheels or just some designs?
xuimod is offline   Reply With Quote
Old 10-04-2016, 03:21 AM   #9
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I personally wouldn't recommend Ambit wheels due to the JWL debacle.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
kch (10-05-2016)
Old 10-04-2016, 06:01 PM   #10
Xxyion
Lowly Cartuber
Xxyion's Avatar
Whats the JWL debacle? Honestly i dont know too much about the company i just know they make cheap wheels that dont look horrible.
Old 10-05-2016, 01:43 AM   #11
menikmati
They had the JWL/VIA stamps on their wheels without actually passing certification.
Old 10-05-2016, 07:42 AM   #12
MarkR171
MarkR171's Avatar
Drives: '05 Elise
That's hilarious. Replica wheels now sporting replica certifications
Their wheels are stated to be "Manufactured in a JWL/VIA Certified Facility"... but the wheels themselves are not certified? haha
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
The Following User Says Thank You to MarkR171 For This Useful Post:
Shark_Bait88 (10-05-2016)
Old 10-05-2016, 02:21 PM   #13
caschnd1
Drives: 2013 Subaru BRZ
I put replicas on my wife's BRZ. She's not doing track days or banging into curbs. Potholes are also not a problem in Arizona. Picked these up from TireRack (18x9) for $200/wheel and mounted Michelin PSS 245/35ZR18 tires on them. The extra grip was needed after adding a supercharger. No trouble at all moving the TPMS from the OEM wheels/tires to the new set.
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl
caschnd1 is offline   Reply With Quote
The Following User Says Thank You to caschnd1 For This Useful Post:
Bowen (10-05-2016)
Old 10-05-2016, 02:47 PM   #14
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
They may be reps, but tire rack doesn't sell shit wheels. They're much pickier than other retailers.
-Josh
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
MarkR171 (10-06-2016)
*** VORDOVEN Forme 9 Wheels - New Lower Pricing for 2015! - Wheels IN STOCK *** Sonic Motor Wheels and Tires 218 03-24-2016 07:23 PM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
