Drives: Ultramarine FR-S 6MT
transmission done?
two weeks ago, my transmission wouldnt go into reverse, first, or second. 3,4,5,6 gears would work, but in those gears, the shifter would be loose and wobbly. it could move 6 inches in any direction and still stay in gear. i drove to my mechanics shop like this, starting from stop in 3rd. when i get there, surprise surprise, the tranny is back to normal. ok so here i am two weeks later. and the tranny has done this again and seems to be stuck this way. i have googled, forum searched etc etc. cant find an answer.
![]() my mech says the linkage is A-ok |
not playing cards
When were you planning on mentioning your trd short shift kit?
Drives: Whiteout FRS
Any mods to your vehicle?
I'll guess the shifter gate plate has come lose or the linkage has just become unglued.
I reckon it's time for someone to open up the top and take a look see at the innards of the shifter. humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#7 | |
| The Following User Says Thank You to swarb For This Useful Post: | cjdriiiiift (09-30-2016) |
not playing cards
Wow! I was absolutely sure that would be the issue. I'm still thinking something is up with the linkage, though.
All the symptoms of a linkage issue. May even be a really simple fix! I call BS on the mechanic.
#10 |
Drive From Home
Drives: BRZ STI Performance
The Subaru service manual will tell you how to gap the reverse lockout plate properly. You would need a feeler gauge from the local hardware store.
Once you remove the shifter boot you should be able to see it. Might need to remove the center console trim as well. The lockout plate needs some grease as well. |
| The Following User Says Thank You to krayzie For This Useful Post: | cjdriiiiift (09-30-2016) |
| Sti transmission | Reaper | Engine, Exhaust, Transmission | 3 | 04-05-2014 06:23 PM |
| Transmission | frosty86 | Issues | Warranty | Recalls / TSB | 7 | 05-16-2013 02:15 PM |
| Transmission? | Pplater | AUSTRALIA | 1 | 06-05-2012 07:17 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
| Which Transmission ? | gatchaman | Engine, Exhaust, Transmission | 15 | 10-29-2009 12:48 PM |
