Old 09-28-2016, 08:55 PM   #1
csong30
Drives: Brz
Air Lift Question
So, I have about 1 to 1.5" left for the fronts. I want to lower it some more, but the air line gets in the way. if I take off the air line and turn it all the way down will I have any issues putting the air line in and have clearance issues because it looks like it hits the lower mount when I turn it up.
Also, I have my camber plates maxed out in the fronts, but may possibly near more camber to clear the wheels better from the struts. Would I need to slot the plates more or would the next step be front lower control arms?
I've never had so much trouble fitting wide wheels when I was on coilovers.... now I have to worry about bags having enough clearance, etc. lol.
csong30 is offline   Reply With Quote
Old 09-30-2016, 10:37 AM   #2
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
Yes, to go lower in the front, take off the air line, then turn it all the way. I would not suggest putting any more camber by the front plates because the bags might rub the frame. Get lower control arms for the front. What size wheels are you trying to fit?
ChanceK is offline   Reply With Quote
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 01:57 PM
EZ Car lift RRnold Other Vehicles & General Automotive Discussions 13 11-09-2012 04:20 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 11:51 AM
