Old 09-23-2016, 03:42 PM   #1
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Alignment Suggestions
Currently, getting back into tracking my car and I'm looking for some good alignment settings (not too worried about tire wear)
The tracks I'll spend most of my time on are:
Laguna Seca
Sonoma
Thunderhill
Suspension & Aero Mods:
Front Camber Bolts
SPC Rear LCA's
RCE Yellow Springs on Stock Shocks
Perrin Front Sway Bar
WRX Rear Sway Bar
Velox Splitter w/ Endplates
Velox Diffuser
SARD LSR Wing
TRD Canards
Tires:
17x8.25 on 225/45/17 Hankook Ventus RS3
Preferably, I would like neutral steer with a crisp turn-in
Tofurky is offline   Reply With Quote
Old 09-23-2016, 04:13 PM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I would talk to Neal at the Racers Line. He lives up your way and runs the same tracks.
Lunatic is offline   Reply With Quote
Old 09-23-2016, 06:01 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
@CSG Mike
TylerLieberman is offline   Reply With Quote
Old 09-23-2016, 09:36 PM   #4
Tenino
Drives: 13' BRZ
I'm currently on -3.1F/-2.5R/0Toe which provides a very neutral feel - 255/40/17 RS3. Aligned by Eric@Elite Performance
Don't have experience with aero setups, but for non-aero, -3.0F/-2.0R/0Toe is a good starting point.
Note: You will not be able to achieve -3.0F with stock strut and camber bolts alone. If you have slotted coils + camber bolts you'll max out around -3.0F. (This is not recommended; however, there are people who run this to stay in certain class for 86cup)
Contact @Elite Performance or @The Racers Line and i'm sure they can help with further details.
Tenino is offline   Reply With Quote
Old 09-29-2016, 01:02 PM   #5
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Laguna Seca
Sonoma
Thunderhill
Front Camber Bolts
SPC Rear LCA's
WRX Rear Sway Bar
Velox Diffuser
SARD LSR Wing
TRD Canards
Tires:
You need front top hats before we can have a real track alignment discussion since your current setup will be less than ideal no matter what you do.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 09-29-2016, 04:57 PM   #6
Cop
Cop's Avatar
Drives: 2013 FRS
Laguna Seca
Sonoma
Thunderhill
Front Camber Bolts
SPC Rear LCA's
WRX Rear Sway Bar
Velox Diffuser
SARD LSR Wing
TRD Canards
Tires:
Selling a set of barely used monosports if you're interested.
Cop is offline   Reply With Quote
Old 10-03-2016, 10:44 PM   #7
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
I was able to get -2.5 on the front
Old 10-04-2016, 12:17 PM   #8
zdr93523
zdr93523's Avatar
That's pretty good but not enough to dial out outer edge wear.
www.makesmodels.com
www.camautomag.com
Old 10-04-2016, 01:23 PM   #9
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I think a good starting point for a primarily track driven car is to get as much in the front as you can and use about 0.5 less in the rear and then fine tune from there. For example, I personally went with -2.2f/-1.7r but this is a year round, daily driven street car and I felt this was a good balance to start off with and so far it's been fine. If it was a primarily track driven car though, I'd be shooting for -3f/-2.5r or so.
Lynxis is offline   Reply With Quote
Looking for DD/track/autocross alignment suggestions. Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-12-2016 12:30 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
OP and FP suggestions Sypher Engine, Exhaust, Transmission 12 03-06-2014 10:56 AM
Any suggestions for my FRS? kaikeng Cosmetic Modification (Interior/Exterior/Lighting) 16 08-04-2013 05:03 PM
