Old 09-23-2016, 10:09 AM   #1
pepe
Drives: gt86
header heat shields
by not mounting toyota header with anti coating heat instead of mounting heat shields?
coating anti heat aftermarket header is not enough to isolate the heat?
Header coating increases temperature in engine compartment?
pepe is offline   Reply With Quote
Old 09-23-2016, 10:59 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Header coatings do not do much for temperature reduction (if anything at all). If you want to lower engine bay temperatures you are going to want to wrap them with header wrap. Pros are reduced engine bay temps and increased exhaust velocity due to higher temps inside them, Cons are reduced header lifespan and possible safety issue if oil ever spills on the wrap and the wrap isn't replaced.
Old 09-23-2016, 11:19 AM   #3
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We have done extensive testing on our ceramic coating process. By ceramic coating the outside and inside of the header, the header has become much more efficient. As a quick note on its effectiveness, we can touch/grab the header within 30 seconds of running the car hard.
Your engine bay temperatures will drop, but it does not mean your engine bay will be completely cool simply because you have heat radiating from various components in the engine bay including the engine and the radiator. Our Trackspec Vents have also proven to be incredibly effective in this case. With a large pressure differential, the vents allow the high pressure air in the engine bay to vent properly into ambient, thereby, exhausting the heat from the engine bay. The result is a very cool engine bay compared to without ventilation.
CounterSpace Garage is offline   Reply With Quote
Old 09-23-2016, 12:18 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
^ Like he said vents + a coating is not a bad idea
Old 09-23-2016, 12:23 PM   #5
pepe
Drives: gt86
My Doubt is:
if header aftermarket assemble ceramic coating (example JDL or similar), the heat is less or the worst case, equal to header header? I would not like it to be more heat.
When you say "our product" to which product you mean?
Old 09-23-2016, 12:28 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
My Doubt is:
There will be a reduction in heat, but a lot of coating don't do a whole lot to reduce the heat, but some do work alright (personally not my thing though)
He means their coating they sell. (BTW they are a great vendor/shop)
Old 09-23-2016, 12:44 PM   #7
pepe
Drives: gt86
heat released by headers : header coating heat It is less than header OEM with shield heat ?
Old 09-23-2016, 12:48 PM   #8
Teseo
Drives: frs
Whish someone produce a heat shield for aftermarket headers
Old 09-23-2016, 12:56 PM   #9
FrostedFlakes
Drives: 2013 Raven FRS
This link may have some helpful information
http://www.ft86club.com/forums/showthread.php?t=77107
I have my header and overpipe ceramic coated and it does keep the heat manageable.
FrostedFlakes is offline   Reply With Quote
Old 09-23-2016, 12:56 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No OEM headers will produce less heat then aftermarket ones with a coating I would think. The difference should be small though
Old 09-23-2016, 12:57 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Just wrap them and replace your headers when they crack That's what I do
Old 09-23-2016, 02:03 PM   #12
CounterSpace Garage
Please also note that if tuning is done improperly, the header may heat up substantially due to higher exhaust temps. A good tune goes a long way as well.
Anyone know the typical temps on the OEM header heat shield? canyons Engine, Exhaust, Transmission 5 08-07-2019 04:24 PM
DIY: PERRIN Motor Mount Heat Shields Koa DIY (Do-It-Yourself) Guides 11 02-02-2018 03:27 PM
Header heat cycling and retighten. Bodalenko AUSTRALIA 3 05-22-2016 06:50 AM
P&L EL HEADER/P&L OVERPIPE HEAT WRAPPED PERRIN CRANK PULLEY AND MORE Anthony7515 Engine, Exhaust, Bolt-Ons 6 06-22-2015 03:20 PM
Heat Shields X Factor Engine, Exhaust, Transmission 4 09-05-2014 03:47 PM
