Old 09-11-2016, 10:44 PM   #1
wutangbrz
Drives: 2015 dgm brz
single wiper blade conversion
Does anyone have information on this? do we need to make modifications to the wiper motor? I cant find any information on this and it seem slike its going to be mostly a DIY type thing. Im guessing cut out a cowl in the middle, move the passenger side wiper motor to the middle and get a wiper big enough?
wutangbrz is offline   Reply With Quote
Old 09-12-2016, 12:13 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I'm curious, WHY would you want it? What gains there are? I know, mercs have single blade .. but probably pros of double blades everybody else in most cases have outweight pros (whatever they be) of single one?
P.S.
As other also might find it difficult to justify such mod, i doubt you'll find info on that here.
Old 09-12-2016, 08:11 AM   #3
15limited
15limited's Avatar
I'm assuming you want to do it #bcuzracecar, you won't see much weight savings from ditching the 2ND motor and wiper assembly, you would be sacrificing visibility as a single wiper in the center of this particular windshield shape would leave large unwiped areas in both corners.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 09-12-2016, 09:20 AM   #4
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
You're limited by the height of the windshield. If a single blade in the middle was long enough to sweep both sides, it'd be sticking past the roof.
If you want a single blade, just remove the passenger one, and suffer the consequences of reduced visibility in the rain.
shiumai is offline   Reply With Quote
Old 09-12-2016, 09:34 AM   #5
lizbrayan
Drives: '15 Scion Frs Steel
Take the passenger side wiper off and move the driver side wiper over to the passenger and call it a day, enjoy your lack of vision with your new gt car wiper.
lizbrayan is offline   Reply With Quote
Old 09-12-2016, 09:39 AM   #6
Oh sweet lord.
Just hire somebody to chase you around when it rains. Can get rid of both that way.
Old 09-12-2016, 11:00 AM   #7
wutangbrz
P.S.
there are no gains tbh. ive been going through old magazines and blogs looking at the original 86 corolla and taking a few mods off that era, and a single wiper conversion was a mod some did.
Old 09-12-2016, 11:05 AM   #8
It was a dumb mod for a street car then and it isn't an better now. To each their own I guess.
Old 09-12-2016, 11:08 AM   #9
wutangbrz
yes to each their own
Old 09-12-2016, 12:02 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
You want a single, center mount wiper?
Remove the driver side wiper blade. Re index the pass. side blade, so it covers more of the drivers side.
If you want the blade to "park" on the drivers side, you'll have to re-index the linkage on the motor, to reverse the blade travel.
I've seen all of these done on minitrucks back in the day.
Gunman is offline   Reply With Quote
Old 09-12-2016, 12:16 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
I'd rather look for retrofitting from already mentioned mercs that have one blade stock. IIRC due it extending outwards when sweeping, it manages to wipe more area then normal single wiper, thus less cons from leaving just one. Or much better .. drop the idea of wasting money/work/time on such mod.
Old 09-12-2016, 12:52 PM   #12
wutangbrz
thanks! ill see if i can find a mini truck tutorial on it
Old 09-12-2016, 01:29 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Video for the single, center mount wiper here:
Old 09-12-2016, 06:36 PM   #14
Gunman
Good luck. Minitruckers weren't much for tutorials, unless one of the magazines did an article, In general, we just figured stuff out, lol
Source for OEM blade inserts FRiSson New England 10 05-06-2014 12:45 PM
Was prying chrome fin blade off my BRZ yesterday... oops KSpider Cosmetic Modification (Interior/Exterior/Lighting) 7 02-22-2014 11:34 AM
what is a good wiper blade? mrlewistan Cosmetic Modification (Interior/Exterior/Lighting) 5 03-18-2013 12:38 AM
Wiper blade spoiler...thingies. Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 2 02-05-2013 05:03 PM
Water Blade VinPetrol Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 10-12-2012 01:21 PM
