Old 09-10-2016, 01:05 PM   #1
zmz0305
Drives: subaru brz
Cracked OFT screen today, what should I do now?
Hi guys, I accidentally dropped my OFT and the screen is cracked! It still does display but touch screen does not work.
I am still in E85 tune and I need to change it back soon because winter here is cold and I need to do maintenance soon.
What should I do now? T_T @Shiv@Openflash
zmz0305 is offline   Reply With Quote
Old 09-10-2016, 01:12 PM   #2
swarb
Call/email oft and see what they can do for you.
The Following 3 Users Say Thank You to swarb For This Useful Post:
Guff (09-11-2016), scary alien (10-10-2016), Tectoniic (09-30-2016)
Old 09-10-2016, 01:13 PM   #3
zmz0305
Drives: subaru brz
I just did email them. Hopefully they will reply soon T_T
Old 09-10-2016, 08:16 PM   #4
steve99
unfortunatly my unserstanding is the OFT which is actually a Alientech powergate 3 device is not repairable.
however shiv has offered a replacement unit for about $250 to people who have damaged the original as you have already paid for tune access.
you could also try alientech usa they may repair but doubt it
http://www.alientech-to.it/index.php.../alientech-usa
The Following 2 Users Say Thank You to steve99 For This Useful Post:
scary alien (10-10-2016), zmz0305 (09-11-2016)
Old 09-11-2016, 12:40 AM   #5
zmz0305
Drives: subaru brz
Oh damn
What about the tune then? The original tune is in my broken OFT, so if I get a new OFT, how do I marry it to my car?
Old 09-11-2016, 01:38 AM   #6
steve99
Oh damn
New oft will still marry up to car no problem, but your "stock" tune will become the E85 UEL tune that's in ECU now.
Unless you know someone with a tactrix cable who can flash you back to stock
Old 09-11-2016, 02:16 AM   #7
zmz0305
Drives: subaru brz
Uuurrrrr! Noooo!!
If I disconnect my battery to discharge everything will ECU go back to stock?
Old 09-11-2016, 02:24 AM   #8
steve99
Uuurrrrr! Noooo!!
no will not work.
tune is flashed to memory in ecu, it does not get reset on power removal or reset.
You need to reflash new tune to ecu to overwrite old one.
on power disconnect or ecu reset only clears the RAM area , this is only learned parameters and CEL codes
have a read of Flashing-Reset-Learning link below
Old 09-11-2016, 02:29 AM   #9
zmz0305
Drives: subaru brz
no will not work.
OMG I am so screwed! On OFT manual it says I should always flash back to stock before going back to dealer for service. Now I do not even have a stock map anymore? So if I go to dealer and dealer touched my ECU then my new OFT will be useless again?
And if I unmarry my OFT the car will always have E85 map?
Is there a way I can just replace a screen or extract data from the broken OFT and transplant it into a new one? @Shiv@Openflash
Old 09-11-2016, 02:48 AM   #10
steve99
no problem I have most of the stock maps.
just let me know your original ECU calibration ID and I give you the stock map.
You can then just load that stock map into the OFT into one of the "tune" slots.
Just flash that before service :-)
or option B
Buy a Tactrix adapter
www.tactrix.com
read the Tactrix link below, then you can flash your ecu with whatever you like.
most of the stock maps are at end of the tactrix link post below
The Following 3 Users Say Thank You to steve99 For This Useful Post:
DarkMatter (09-11-2016), DarkSunrise (09-11-2016), scary alien (10-10-2016)
Old 09-11-2016, 01:04 PM   #11
zmz0305
Drives: subaru brz
or option B
www.tactrix.com
It is so nice of you sir!
Just curious is Tactrix able to write OFT tune files to ECU?
Old 09-11-2016, 08:36 PM   #12
steve99
yes, just not as simple as oft.
Old 09-30-2016, 04:38 PM   #13
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
I'm sort of in the same boat. Congratulations dude, THE TUNE GODS HAVE YOU NOW....
MUAHAHAHAHA
Subie_Nubie is offline   Reply With Quote
Old 10-10-2016, 12:14 AM   #14
Subie_Nubie
Update: I am working on a repair DIY thread. Stay tuned.
The Following 2 Users Say Thank You to Subie_Nubie For This Useful Post:
scary alien (10-10-2016), Teseo (10-10-2016)
head unit screen cracked flat486 Issues | Warranty | Recalls / TSB 5 01-15-2016 01:44 AM
OFT cracked screen minutes after receiving.. Vitamin-R Software Tuning 15 07-06-2015 11:56 PM
Cracked Screen on an OFT Thrustin Software Tuning 3 08-03-2014 07:29 PM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 03:28 PM
T7019A HELP boot screen or splash screen change Trap63 Electronics | Audio | NAV | Infotainment 2 06-09-2013 06:04 PM
