Old 09-07-2016, 01:56 PM   #1
Terruko
Terruko's Avatar
LED stripe doesn't turn on on my FR-S
Bought this FR-S last week and just noticed mine doesn't turn on, is it burned or what?
Mine is the right one.
Terruko is offline   Reply With Quote
Old 09-07-2016, 01:59 PM   #2
Cole
Not a troll
Cole's Avatar
It doesn't turn on when your headlights are on. Or when your parking brake is on. Or when you're in park.
The Following User Says Thank You to Cole For This Useful Post:
Hot-Lava_Dave (09-07-2016)
Old 09-07-2016, 02:01 PM   #3
Terruko
Terruko's Avatar
Ooh, I'll check later then. Thank you.
Old 09-07-2016, 02:08 PM   #4
humfrz
Welcome to ye ol forum............
I'd suggest you first check the fuse.
Then check for a bad connection/ground.
Is it just one side that isn't working .. ??
humfrz
Old 09-07-2016, 02:08 PM   #5
Terruko
Terruko's Avatar
Both sides don't work. Maybe it's what Cole said.
Old 09-07-2016, 02:45 PM   #6
humfrz
After you check that .......keep us posted......
humfrz
Old 09-07-2016, 02:52 PM   #7
It is what Cole said.
Look in glovebox.
Find book in a case.
Read said book.
Many mysteries will be explained.
Old 09-07-2016, 02:59 PM   #8
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
^Yup. Those are Winjets, I have them on mine and the LED strips are for DRL only. They also should illuminate when you flip on your highbeams. I believe there is an always on module made by Diode Dynamics that you can purchase if you want them on with headlights turned on as well.
Hot-Lava_Dave is offline   Reply With Quote
The Following User Says Thank You to Hot-Lava_Dave For This Useful Post:
Tcoat (09-07-2016)
Old 09-07-2016, 03:10 PM   #9
I thought they were Monogram lights. Oh well, still read the book since it still talks about DRLs..
Old 09-07-2016, 03:16 PM   #10
Brayden_23
Drives: Asphalt 2015 FRS
You can tell they are Winjets due to the black housing and metallic ring around the headlight. Winjet also makes a chrome version to look more OEM but you can still tell the difference based on the color of a little triangle at the bottom that OEM leaves black whereas it will be all chrome on the Winjets.
These still function the same as OEM though.
OP - have someone get in the car and act like they are going to drive it away. You will see the lights come on.
Brayden_23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brayden_23 For This Useful Post:
Hot-Lava_Dave (09-07-2016), Tcoat (09-07-2016)
Old 09-07-2016, 05:05 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
And then OP will never see the car again.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Brayden_23 (09-07-2016), dnieves (09-07-2016)
Old 09-07-2016, 07:09 PM   #12
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
http://www.beatsonicusa.com/dlm2ep.html
You're welcome.
KalbiCool88 is offline   Reply With Quote
The Following User Says Thank You to KalbiCool88 For This Useful Post:
trvth (09-21-2016)
Old 09-09-2016, 08:05 PM   #13
WNCFRS
Drives: 2016 FRS RS 2.0 auto #921
I did the same thing. Every time I got out to look they weren't on. Pull into a garage or against a wall and you will see them.
WNCFRS is offline   Reply With Quote
Old 09-09-2016, 08:06 PM   #14
Terruko
Terruko's Avatar
Yupp, Cole was right.
The Following User Says Thank You to Terruko For This Useful Post:
wireman957 (09-09-2016)
FS: BRZ tS pin stripe Silver Khazzy Exterior Parts (Aero, Lighting, Etc.) 18 05-30-2018 10:52 AM
To Stripe or Not To Stripe... ShaneLindley Cosmetic Modification (Interior/Exterior/Lighting) 25 10-12-2015 06:47 AM
Nismo red stripe? Papi BRZ First-Gen (2012+) — General Topics 43 10-11-2015 04:28 PM
Why doesn't traction/stability control actually turn off? Ganthrithor BRZ First-Gen (2012+) — General Topics 84 09-13-2015 01:37 PM
Hood stripe Tamoor Cosmetic Modification (Interior/Exterior/Lighting) 16 03-27-2013 10:20 PM
