Old 09-07-2016, 09:30 AM   #1
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
P3 Boost gauage HKS Supercharger kit tap in.
So got my HKS kit with the smaller pulley making 11.5 lbs of boost but stock MAP sensor only reads 5.5 max. I picked up omni 3 bar but the HKS can tune doesn't read it. So I order the analog boost tap for the P3 kit just curious if any one with the HKS kit or P3 gauge has any tips.
Thanks guys love the kit and the P3 gauge.
Gearbanger is offline   Reply With Quote
Old 09-07-2016, 09:55 AM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The P3 picks up boost through OBD. You have to scale the sensor in the ECU ROM otherwise the 3 bar won't work period, with the gauge or ECU. Once the ECU is scaled to it, the P3 will have no problem reading it. What are you using to tune it? Any tuner can update the scaling for you. If you flashed the ROM yourself it's very easy to change as well.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 09-07-2016, 10:56 AM   #3
Gearbanger
Gearbanger's Avatar
HKS can tuned for e85. I ordered an analog boost accessory from PS wheres a good place to pick up the boost reading from the HKS kit? Boost gauge port or Vacuum tap. Thanks
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release CounterSpace Garage Forced Induction 313 03-08-2021 07:39 PM
Supercharger boost at high altitude Toyota86.ir Software Tuning 2 02-03-2016 12:13 PM
Can you notice the supercharger's parasitic drag off boost? stevo585 Forced Induction 3 03-12-2014 04:00 PM
Comparison between a supercharger and a turbocharger at the same boost level buditjoenawan Forced Induction 50 10-04-2013 02:21 PM
