Drives: 2016 BRZ
DIY reprogram for TPMS?
I've seen the ATEQ gear. It seems like an expensive solution for this problem. Are there other options for reprogramming the TPMS when you switch wheels? I'd like to avoid the inconvenience of having to take it to a shop every 6 months.
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Drive without TPMS for 6 months out of the year and check your tire pressures weekly manually? Cheapest DIY option available. I have four sets of wheels and tires for my BRZ and only the stock wheels (which are just on for winter storage) have TPMS sensors in them.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
Drives: 2016 BRZ
TPMS is too valuable for me to give up. It has triggered on my previous vehicles 3 times and in each case the advanced notice turned impending tire failure into an easily resolved situation. Weekly checks would not have worked out nearly so well.
I'll pay what I have to keep it functioning, just hoping for a less expensive option. |
not playing cards
Techstream for sure. I think someone mentioned Carista but I could be full of shit.
Drives: 2016 BRZ
Would Techstream work with BRZ?
I've heard mixed responses about Carista. Waiting to hear from the developer. |
not playing cards
Oooo, good question. I bet all the Subie dealerships have it for the BRZ.
Drives: 2016 BRZ
Carista says they are developing this capability and it is currently in beta testing. They offered to let me participate, so we'll see.
| The Following User Says Thank You to cjny For This Useful Post: | Ultramaroon (09-07-2016) |
#8 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
In Southern California Discount Tire does this - I have no affiliation other than being a satisfied customer. I bought a set of TRD wheels with tires and TPMS sensors from someone who wanted to track their car and bought lighter wheels... much to my surprise my local Discount Tire swapped the wheels and reprogrammed the TPMS for no charge even though I did not buy the tires or wheels from them! Good luck! |
| The Following User Says Thank You to nextcar For This Useful Post: | cjny (09-08-2016) |
Drives: 2013 Subaru BRZ
You can get TPMS that can be cloned to match your OEM sensors. This will give you two sets of identical TPMS that require no reprogramming when you swap wheels.
-Craig
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl |
#10 |
I have the ATEQ. Seemed like a tool worth the cost. Use it twice a year to keep TPMS in sync.
#11 |
Wheel/tire packages don't leave our property without TPMS if the car requires it. Wouldn't that light bug you constantly?
#12 | |
I still hate the idea that it is required on all new cars. Thank goodness I don't have to run it when I swap to other wheels/tires. I would have spent thousands of dollars in the last 8 years if I had put TPMS in every aftermarket set of wheels I bought. At least some manufacturers are going back the wheel speed sensor TPMS setup (like my '05 Mini has), which don't require individual sensors in each wheel anymore.
#13 | |
Drives: 2016 Scion FR-S RS 2.0
2016 Scion FR-S Release Series 2.0 #170/1000
#14 |
I've only had a couple of false tire pressure alarms in the Mini in the 11 years we've had it, but the speed sensors they use for TPMS weren't that accurate (which is why they had to stop using that system in 2008 when TPMS became mandated by the US govt). I guess the newer wheel speed sensors, like what Mazda is now using to get by without having individual TPMS sensors in each wheel, are accurate enough to meet the govt standards.
| Can I reprogram my head unit with someone else's SD card? | radroach | Electronics | Audio | NAV | Infotainment | 30 | 03-29-2016 01:50 PM |
| AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments | AZP Installs | Wheels and Tires | 0 | 04-28-2014 11:00 PM |
| AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments | AZP Installs | Mechanical Maintenance and Tools | 0 | 04-28-2014 11:00 PM |
| AZP May Specials:TPMS Reprogram/Clone, Track Day and Alignments | AZP Installs | NY / NJ / CT / PA | 0 | 04-28-2014 10:59 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
