Old 09-05-2016, 02:27 PM   #1
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Regrease top mounts?
So my front coils are making a noise from the front strut when turning and I thing the bearings are dry and need more grease.
Can this be done just from the top or do I need to disassemble the coils to get underneath too? Do i need to cleanr the grit/grime out beforehand with say rubbing alcohol or just a q-tip or something like that?
Old 09-05-2016, 02:31 PM   #2
Cole
Not a troll
Cole's Avatar
It's been a while since I've looked at my stock top mounts (assuming that's what you're talking about) but I feel like you can see the bearings when you pop that little cap off. You could use WD40 to get some of the grime out, then use a lithium grease to lube everything up.
I could be wrong though, so maybe ignore that whole post.
Old 09-05-2016, 02:35 PM   #3
Ro_Ja
Drives: TOYOTA
If your top mounts have a spherical bearing, do not (re)grease with anything. They are self-lubricated by a teflon lining. Greasing them will only attract more contaminants. Depending on the quality of the bearing and conditions it has gone through, it is possible that lining has deteriorated. If so, you will need to replace it. I suggest contacting the manufacturer of the top mounts you bought and ask about service options.
Ro_Ja is offline   Reply With Quote
The Following User Says Thank You to Ro_Ja For This Useful Post:
finch1750 (09-05-2016)
Old 09-05-2016, 02:49 PM   #4
finch1750
finch1750's Avatar
thanks for the info, but it is aftermarket top hats (should have made that more clear since not all coils come with tophats.
thanks. didnt know that.
Phone Mounts tekFRS234 Cosmetic Modification (Interior/Exterior/Lighting) 159 06-01-2020 10:34 AM
STI motor mounts AdrianG Canada Classifieds 2 10-23-2015 09:01 AM
WTB: top mounts sdwagonjp Want-To-Buy Requests 1 06-07-2015 09:10 PM
Ram Mounts kizmar Scion FR-S / Toyota 86 GT86 General Forum 4 01-17-2015 09:58 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
