Old 09-02-2016, 08:29 PM   #1
Lumbajackmeh
Drives: 2015 FRS
Stage 2 UEL E85 Tune - Issue - Slightly Nervous and Very New to This
The below is with an OFT E85 Tune.
So I've been running E85 for a couple of weeks now and just installed an unequal length header and flashed to the Stage 2 UEL Tune. I took a slow cruise on it and I'm nervous about the levels I was seeing. So, when cruising my AFR would be around 14:1 and when I let off the gas it shoots up to 20:1. I've never looked at the AFR when I left off the gas before so I don't know how normal or how bad this is.
The knock correction was sitting at zero and ignition advancement was bouncing around 40 degrees.
Note, I could hear an exhaust leak from the front pipe the mid pipe which I'm taking care of.
I appreciate any help or advice what to do.
Lumbajackmeh is offline   Reply With Quote
Old 09-02-2016, 08:35 PM   #2
Pro60modman
Drives: Too many
Your injectors shut off when you take your foot off the gas and coast so the AFR guage will go full lean so seeing 20 is normal. Optimal cruising AFR is 14.7. Take the exhaust pieces that are leaking off and spray the gaskets with Permatex Copper Spray then reinstall.
EDIT: Most cars cruise around 35-45 degrees ignition advance and as far as I have observed tuning BRZ and FR-S myself KCA doesn't engage until you are in open loop.
Pro60modman is offline   Reply With Quote
The Following User Says Thank You to Pro60modman For This Useful Post:
gonzo (09-09-2016)
Old 09-02-2016, 08:40 PM   #3
Lumbajackmeh
Drives: 2015 FRS
After I sent this, the AFR thing made me feel dumb. I went "duh, you're not adding more fuel"
The other things are what concerns me. I imagine making sure everything is sealed up better I should feel better about.
Old 09-03-2016, 11:43 PM   #4
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
lol.. dont worry...i was like this when i was into modding car back in time.
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
OFT Stage 2 uel 91 ISSUE Flat_4_Life Software Tuning 3 04-19-2015 09:44 PM
OFT Stage 2 UEL tune concern iris mm Software Tuning 19 03-16-2015 06:46 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Perrin Stage 1 Tune brz007 Northwest 5 10-03-2012 05:59 PM
