| AUSTRALIA Australia and New Zealand |
Drives: '07 Civic Type R
Slimline Plates Plate Bracket
Posting this in its own thread as it seems to be lost in the other thread.
Here are some renders of an early prototype of a bracket for slimline plates. With plate: ![]() Without plate: ![]() Different view with plate: ![]() Different view without plate: ![]() Right profile view: ![]() The goal was to create an OEM looking plate bracket that also acted as a frame for the plate. So as you can see the design itself is based on the OEM bracket, matching the exact body contours/curvatures of the car. It will bolt directly onto the existing holes without any modifications required. We've also tried to cover up the bottom two holes (inside the grille) from the OEM bracket, however, if someone who already has the car can remove their plate and bracket and take a picture we can then be certain we have successfully done so. Anyways, we're still not sure whether we'll put these into production, let us know how many of you guys will be interested in possibly buying one of these and we can probably work something out. Update (9/7/12): We'll most likely be producing two versions in the following sizes:
#2 |
Drives: 86 GTS Auto in Pegasus White
Possibly interested. What price (ballpark), and what dimension for the plate?
#3 |
Drives: 86
What size will it be?
I think NSW has a smaller slimline plate than QLD and our plate won't fit if this is made for NSW plate. |
#4 |
Drives: '12 BRZ [CBS]
#5 |
Drives: Toyota 86 GTS
ill definitely be interested in this. +1.
#6 |
We can produce them in any dimensions if we get the necessary numbers for each size.
In terms of pricing, we're working on the cheapest possible pricing without sacrificing quality. Will keep you guys posted. We might also be looking into producing some carbon fibre ones as well. Last edited by eleu2166; 07-08-2012 at 09:34 PM. |
#8 |
Drives: 86 GTS 6AT
If you can price it <$100 I would be interested.
#9 |
Pegasus White
Drives: 86
How many would you need to do a run on a perticular size?
I have a different size plate wouldn't mind an OEM looking holder for it.
Driving: Pegasus White Manual GTS 86.
#10 |
Drives: Mt Fuji Red 86 GT
Also would be keen for a slimiline plate holder for QLD size. Pending price/quality obviously
#11 |
Drives: 86
#12 |
Drives: Sonic Blue 86 GTS 6AT
Here's a rough idea of different plate sizes for different states. In general a slimline plate is 372mm x 100mm but as you can see there are also plenty of variations on that.
![]() Australian Capital Territory. Standard vehicle plates (same size front & rear): 1/2 size, 3 characters max are 133mm high x 190mm wide 3/4 size, 5 characters max are 133mm high x 317mm wide Full size, 7 characters max are 133mm high x 372mm wide Slimline plates (Front of vehicle only): 1/2 size, 3 characters max are 100mm high x 190mm wide 3/4 size, 5 characters max are 100mm high x 317mm wide Full size, 7 characters max are 100mm high x 372mm wide New South Wales. Prestige Plates (Acrylic Plates with Aluminium Frames): 95mm high x 372mm wide. Premium Metallic Plates: 84mm high x 372mm wide (front), 107mm high x 372mm wide (back) Euro Plates: White Euro Front and Back: 110mm high x 520mm wide Black Euro Front: 84mm high x 372mm wide, Back: 110mm high x 520mm wide Euro "Icon" Front: 84mm high x 372mm wide, Back: 110mm high x 520mm wide Themed Plates: 134mm high x 372mm wide Colourful Choice Plates: 84mm high x 372mm wide (front), 107mm high x 372mm wide (back) White Plates: 84mm high x 372mm wide (front), 107mm high x 372mm wide (back) Custom Yellow and Black Plates: Varies depending on chosen content. Front and back maximum size: 134mm high x 372mm wide Yellow Plates: 134mm high x 372mm wide Northern Territory. Standard plates: 372mm wide x 133mm high Medium plates: 315mm wide x 133mm high Small plates: 190mm wide x 133mm high Slim Line plates: 372mm wide x 100mm high Combination Slim and Standard plates: 372mm wide x 100mm high (front), 372mm wide x 133mm high (rear) Queensland. Standard plates: 372mm wide x 134mm high Slimline plates: 372mm wide x 100mm high US Size plates: 300mm wide x 152mm high Slimline Euro plates: 372mm wide x 100mm high Classic Euro plates: 520mm wide x 112mm high 2 x 2 Flexi plates (Acrylic): Standard - 291mm wide x 135mm high Slimline - 291mm wide x 100mm high Standard - 372mm wide x 135mm high Slimline - 372mm wide x 100mm high Prestige plates (Acrylic Plates with Aluminium Frames): Standard size - 372mm wide x 135mm high Slimline size - 372mm wide x 100mm high South Australia. For more details visit this link. Standard plates: Standard: 371mm wide x 133mm high Slim: 371mm wide x 100mm high Custom plates: Standard: 371mm wide x 106mm high Slim: 371mm wide x 83mm high Square: 300mm wide x 150mm high Personalised plates: Standard: 371mm wide x 133mm high Slim: 371mm wide x 100mm high Premium plates: Standard: 371mm wide x 106mm high Slim: 371mm wide x 83mm high Square: 300mm wide x 150mm high Euro plates: 520mm wide x 112mm high Tasmania. Standard plates: 372mm wide x 134mm high Slimline plates: 372mm wide x 100mm high Euro plates: 522mm wide x 114mm high Victoria. Custom Plates: Standard size plates (3 to 6 characters) are 372mm wide x 132mm high Slimline plates (6 characters) are 372mm wide x 100mm high Slimline plates (5 characters) are 315mm wide x 100mm high Slimline plates (3 or 4 characters) are 250mm wide x 100mm high Euro Plates: Standard Euro Plates are 520mm wide and 112mm high. Mini Euro Plates are 372mm wide and 100mm high. Signature Plates: Standard Signature Plates are 255mm wide x 137mm high Slimline Signature Plates: are 255mm wide x 105mm high Grand Prix Plates: Standard plates are 380mm long x 140mm high. Slimline plates are 380 mm long x 106mm high. Footy Plates: Standard size only available 372mm x 132mm Heritage Plates: One Digit Heritage Plates are 197mm wide x 114mm high Two Digit Heritage Plates are 203mm wide x 114mm high Three Digit Heritage Plates are 228mm wide x 114mm high Four Digit Heritage Plates are 338mm wide x 114mm high Five Digit Heritage Plates are 406mm wide x 114mm high Six Digit Heritage Plates are 456mm wide x 114mm high Western Australia. Custom Plates: Slimline aluminium & polycarbonate are 372mm wide x 100mm high 1/2 size aluminium & polycarbonate are 190mm wide x 134mm high 3/4 size aluminium & polycarbonate are 315mm wide x 134mm high Normal size aluminium are 372mm wide x 134mm high Normal size polycarbonate are 375mm wide x 134mm high Slimline series: Slim line aluminium - 372mm wide x 100mm high Retro and Blue plates: Standard front and back are 372mm wide x 134mm high Slim line front and back are 372mm wide x 100mm high Slim line front is 372mm wide x 100mm and standard rear is 372mm wide x 134mm high Corporate fleet plates: This plate series is only available in 372mm wide x 134mm high Europlates: The europlate measures 520mm wide x 111.8mm high |
#13 |
Drives: 86 GTS
Lakin Plates here: http://www.lakinplates.com.au/index....54_107_767_768
Already does a plate holder specifically for the 86 and if you tell them plates you are putting on, they can even do the right plate covers for them (I've ordered mine for QLD slimlines). |
#14 | |
| Grimspeed Tag bracket on dgm | Coastermikey | BRZ First-Gen (2012+) — General Topics | 19 | 06-25-2012 06:54 PM |
| AMT rear sway bar bracket | adamturbo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-13-2012 11:06 AM |
| 2013 BRZ License Plate Bracket Kit Installation Revision | taosracer | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 05-26-2012 02:28 PM |
| CUSTOM PLATES OR REGUALR PLATES? | Koomoo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-21-2012 09:38 PM |
