Old 08-30-2016, 11:50 AM   #1
Ashikabi
Ashikabi's Avatar
How to increase negative camber Fortune 500 coilovers
I got a set of Fortune 500s. I'm veto happy with them except I can only get about -2.5 camber on them. I'd like -3 to -3.5. How can I go about getting more camber without modifying the coils(voids warranty)?
Top hat is maxed out. I don't have camber bolts(yet), can someone verify fitment? Fortune said I could make the top hole in the bracket longer away from the shock(voids warranty) but when I visualize this it decreases(+) camber. Any ideas guys?
Old 08-30-2016, 11:54 AM   #2
gramicci101
Off Topic
Camber bolts would be my immediate suggestion. Or camber bolt in the bottom hole and crash bolt in the top hole. Or two camber bolts. You could slot the top hole of the strut, but like you said, that voids the warranty.
The Following User Says Thank You to gramicci101 For This Useful Post:
Cole (08-30-2016)
Old 08-30-2016, 12:15 PM   #3
Ashikabi
Ashikabi's Avatar
I know one hole already is slotted. I think the top one but it's obviously not enough. How are crash bolts different from normal/camber bolts?
Old 08-30-2016, 12:27 PM   #4
gramicci101
Off Topic
The OEM bolts are 16mm top, 14mm bottom. The crash bolt is also 14mm (same part as the OEM lower bolt). It's just a thinner bolt than the top bolt, whereas a camber bolt has an eccentric lobe on it. People will pick up another 14mm bolt and put it in the top hole, to get a little camber. Or they'll take the OEM bottom bolt, put it in the top hole, and put a camber bolt in the bottom hole, to get some more camber. Or two sets of camber bolts, one in each hole. This will give you the most.
Old 08-30-2016, 12:32 PM   #5
Ashikabi
Ashikabi's Avatar
Isn't the stock top bolt supposed to be a camber bolt?
Old 08-30-2016, 12:36 PM   #6
gramicci101
Off Topic
It's just a plain old round bolt. Or at least, mine was. It's just bigger than the bottom bolt, so when you put another bottom bolt in the top hole, you get a little bit of play.
Old 08-30-2016, 03:08 PM   #7
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
https://store.partsshopmax.com/shop/.../ZNC6FLCA.html
KendallH is offline   Reply With Quote
Old 08-30-2016, 03:14 PM   #8
Ashikabi
Ashikabi's Avatar
Originally Posted by KendallH View Post
Yeah I was hoping to stay under 800$ but thanks for the link.
Camber bolts ordered, hope they fit
Old 08-30-2016, 07:30 PM   #9
Cole
Not a troll
Cole's Avatar
Definitely camber bolts. That's realistically your only option without going custom top hats.
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Negative Camber! victorchav Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-08-2016 12:51 PM
Negative front camber? Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-23-2014 06:33 PM
Advice on negative rear camber Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-27-2013 10:38 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
