Old 08-24-2016, 11:29 AM   #1
chezzy79
chezzy79's Avatar
Drives: 2015 BRZ
Upgrading the speakers on a system with OEM Audio Plus installed
I have the OEM Audio Plus for BRZ installed currently, which includes:
-1" Soft Dome tweeter
-8" 100W Subwoofer
-120W Subwoofer Amplifier
-Multi-Channel 32-Bit DSP Power Amplifier (360 Watts RMS Continuous / @ 2-ohms)
I feel like I can get a lot of improvement by replacing the stock speakers, including the tweeter that was replaced by OEM Audio+. However, I have almost no experience in car audio, and am wondering if anybody could give me suggestions on upgrading the tweeter, midrange, door, and rear speakers of the car. My budget for this would be around $1000-1500.
Thank you in any advance for any help.
chezzy79 is offline   Reply With Quote
Old 10-12-2016, 02:23 AM   #2
gskv
Drives: 2017 BRZ
The OEM+ comes with 4" mid range, and 6.5" woofers now.
You could just pick those up as extra ones?
gskv is offline   Reply With Quote
Old 10-12-2016, 10:53 AM   #3
Chimera
Drives: FRS
prob the most straight forward solution would be contacting them about upgrading your existing setup. at least that way you know all your parts will compliment eachother. I think they do DSP retunes when you upgrade, you might be out of your dsp for a little bit, but Im not sure.
Edit: Or you could sell your existing solution and go for a custom setup if that's your interest.
Old 10-12-2016, 03:50 PM   #4
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Yep, just go to OEM Audio Plus and ask them for the upgrade...easy.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 10-12-2016, 08:22 PM   #5
gskv
Drives: 2017 BRZ
I just ordered the entire speaker replacement with the amp.
I'm usually a balanced audio type of guy--but I went with robust just to see what it'll do.
I hope I don't regret it with too much bass. But I mean, it's only 100rms. lols.
Old 10-12-2016, 08:44 PM   #6
gramicci101
Off Topic
Honestly that's one reason I haven't pulled the trigger on the OEM Audio+ setup. Right now I have an 8" with 200w RMS, and it's right about where I want it, although I'm contemplating stepping to a 10" for lower extension. I worry that stepping down to 100w RMS might leave me wanting more bass.
Old 10-12-2016, 09:16 PM   #7
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
+1 for contacting OEM Audio + about upgrading speakers.
I started off with just the basic "system" and upgraded after I heard the reference system in my wife's car. It's worth it.
As for bass, it's strong enough to make the music (bass included) the only thing you hear at highway speed. (And I am running a Borla cat-back)
Twinz is offline   Reply With Quote
Old 10-17-2016, 03:25 PM   #8
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Definitely suggest contacting their customer service. They're excellent.
I have the reference system in my car, OEM A+ is super responsive, have upgraded speakers, and can re-tune the DSP for your car as well. They can also re-tune for new head units as long as it's nothing too crazy. I plan on upgrading my head unit soon and the having them kick up the bass a notch since I went for the mid-level and I have to turn the volume over 25-30 it seems for the sub to start kicking.
DoomsdayJesus is offline   Reply With Quote
upgrading audio for the car wingrider Electronics | Audio | NAV | Infotainment 13 09-10-2016 02:52 PM
New Audio System: OEM Audio+ Reference, Audison Prima 8.9, or Hertz Energy setup? gamjatang Electronics | Audio | NAV | Infotainment 10 12-04-2015 04:12 PM
Shop Suggestion Wanted: Audio upgrade and sound-deadening (Upgrading to OEM 400+) chezzy79 Northwest 10 09-11-2015 12:36 PM
Upgrading Car Audio with only $800 TB9 Electronics | Audio | NAV | Infotainment 6 02-02-2015 02:28 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
