Old 08-21-2016, 10:42 PM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
How do i read this?
How do i read this? How do I know its good or bad??
It is a stage 2 tune.
Thanks
During IDLE , before drive
Is it normal for intake air T to be that high during IDLE???
After drive
How come intake air T lowered after a mild drive?
I have a greddy intake.
FR-Sky is offline   Reply With Quote
Old 08-21-2016, 10:49 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The sensor doesn't lie. If you think about how engine and intake work and what environment the sensor is in, it should make 100% perfect sense.
The Following User Says Thank You to Wayno For This Useful Post:
Trac Toy (08-22-2016)
Old 08-21-2016, 11:26 PM   #3
steve99
Id be more concerned with the 17% ltft, that high and positive usually indicates an exhaust leak, or maf scaling is off. it will vary arround a bit at idle due high intake air temps maybe to 8 or 10%, but 17 usually indicates some issue
FR-Sky (08-22-2016)
Old 08-21-2016, 11:43 PM   #4
Teseo
Drives: frs
But a leak will throw cel, right?
Old 08-22-2016, 12:19 AM   #5
FR-Sky
FR-Sky's Avatar
So does that mean i should check the connection of the exhaust system??
I am running stage 2 91 oft, UEL borla header , greddy intake and stock exhaust.
Old 08-22-2016, 12:20 AM   #6
FR-Sky
FR-Sky's Avatar
I dont see any cel popping up.
Old 08-22-2016, 03:28 AM   #7
steve99
Arrh Gready intake, that will be whats causing high fuel trims , as im assuming you have not rescaled maf to suit intake
Old 08-22-2016, 03:30 AM   #8
steve99
not always
fuel trims max out at 40% when trims hit that then you will throw cell
Teseo (08-22-2016)
Old 08-22-2016, 03:31 AM   #9
FR-Sky
FR-Sky's Avatar
Yea...i dont know how...thats why i am having this post on how to read this.
Can you please show me or teach me? Thanks
sorry..i am a novice this....
Old 08-22-2016, 03:42 AM   #10
steve99
Ok its going to require a bit of reading and learning
start here
http://www.ft86club.com/forums/showt...01#post1842501
then when you can log with oft to a file and save logs to computer
you will need to input the data to the vgi maf scaler program
http://www.ft86club.com/forums/showthread.php?t=64790
then you ging to need to learn how to use romraider a tune editor
http://www.ft86club.com/forums/showthread.php?t=79152
if all that looks to much then either put stock intake back on and just get drop in filter or pay someone to scale maf for you
The Following 2 Users Say Thank You to steve99 For This Useful Post:
FR-Sky (08-22-2016), Teseo (08-22-2016)
Old 08-22-2016, 04:33 AM   #11
FR-Sky
FR-Sky's Avatar
start here
so sad......."put stock intake back on and just get drop in filter or pay someone to scale maf for you"
Will my engine blow up ?!
Ok wait a minute, so first of all, i rec and take the data out from OFT manager? And then i start from there?
What is a normal % for LTFT??
Old 08-22-2016, 05:17 AM   #12
steve99
it probably not going to blow up.
its probably going to be a bit hesistant or bog a bit when you get on throttle.
but check yor wide open throttle afr it should be low 12 to high 11 on oft tune
but yes log the required parameters put them through the vgi utility it will generate new maf scale for you then transfer into maf table in tune using romraider, then flash updated tune and probably repeat 2 or three times.
your probably aiming for ltft of 5%
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Brakes, Suspension, Chassis 2 04-17-2014 02:47 PM
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Engine, Exhaust, Bolt-Ons 2 04-17-2014 02:11 PM
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Wheels and Tires 1 04-17-2014 02:10 PM
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Miscellaneous 0 04-14-2014 07:48 PM
