Drives: FRS
Air filter for stock box : K&N or Perrins?
Just curious which one is better or what do you guys prefer? K&N or Perrins air filters for the stock box.
Drives: frs
Whatever fit your budget
Drives: FRS
i got the K&N but my friend gave me the Perrins so debating should i swap it out.
Drives: 2014 Ultramarine FR-S
OEM.
Buuut if I had to pick an aftermarket filter, I'd go Cosworth or A'PEXi. |
TRD worked for me : )
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
Drives: 2014 Subaru BRZ Limited WRB AT
Cosworth for me. Definitely better throttle response than stock.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
[insert cool phrase here]
Drives: BRZ Premium
What ever you want, what ever your wallet thinks is best. They all perform the same.
Also depends how much of a germaphobe you are when its time to cleaning the filter. If you don't want to clean it, get the dry ones.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Like the two posters earlier in the thread, I can offer a third recommendation for the Cosworth drop-in filter. I was initially suspect of any benefit, but now I'm a believer - once installed, the engine revved more freely, had noticeably better throttle response, and sounded better, too. Is it a game changer? No, of course not - but it was a nice improvement for less than $50. Easily recommended.
Since the difference power wise between those two is so minimal personally I would go with the Perrin because it looks cooler.
#10 |
Drives: BRZ Premium
Any performance drop in filter would do the same exact thing. It would sound nice, rev freely, all butt dynos will be the same.
I went with K&N cause 1. It was $45 at Walmart 2. It's pretty much a midget TRD clone. 3. I have K&N filters on my MR2 Turbo with zero problems over the last 10 years. But, it really was a coin flip from getting the Apex or other dry filters.
#11 |
Drives: 2015 FRS Asphalt
Apexi nuff said.
https://www.rallysportdirect.com/fit...i-panel-filter |
#12 |
I reckon it doesn't matter ........
![]() humfrz |
#13 |
Huge E85 fan!
Drives: 2016 Scion FRS
| The Following User Says Thank You to guybo For This Useful Post: | Amputechture (08-19-2016) |
#14 |
TRACKBREAD
I went with the AFE pro dry S filter, mainly because I'm not a fan of oiled filters on MAF cars, the dry filters have better filtration, and I've had good luck with their products in the past.
-Josh Last edited by Yoshoobaroo; 08-19-2016 at 03:47 PM. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | JazzleSAURUS (08-19-2016) |
| Need Help on Replacing Stock Air Filter | Sookainian | Engine, Exhaust, Transmission | 5 | 03-15-2014 09:47 PM |
| WTB: Stock air intake filter box | BatStig | Canada Classifieds | 8 | 08-15-2013 09:09 AM |
| Perrins new CAI vs Perrin drop in filter. Thoughts? | NickFRS | Engine, Exhaust, Transmission | 76 | 01-22-2013 12:39 AM |
| K&N Drop-In Filter for BRZ/FR-S in stock! | Mach V Dan | Engine, Exhaust, Bolt-Ons | 0 | 06-27-2012 02:41 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
