Old 08-18-2016, 07:32 PM   #1
stevenkuo127
Drives: FRS
Air filter for stock box : K&N or Perrins?
Just curious which one is better or what do you guys prefer? K&N or Perrins air filters for the stock box.
stevenkuo127 is offline   Reply With Quote
Old 08-18-2016, 07:42 PM   #2
Teseo
Drives: frs
Whatever fit your budget
Old 08-18-2016, 08:37 PM   #3
stevenkuo127
Drives: FRS
i got the K&N but my friend gave me the Perrins so debating should i swap it out.
Old 08-18-2016, 09:04 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
OEM.
Buuut if I had to pick an aftermarket filter, I'd go Cosworth or A'PEXi.
Old 08-18-2016, 09:06 PM   #5
makesdrivingfunagain
TRD worked for me : )
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
makesdrivingfunagain is offline   Reply With Quote
Old 08-18-2016, 09:30 PM   #6
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
Cosworth for me. Definitely better throttle response than stock.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
Old 08-18-2016, 09:33 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What ever you want, what ever your wallet thinks is best. They all perform the same.
Also depends how much of a germaphobe you are when its time to cleaning the filter.
If you don't want to clean it, get the dry ones.
Old 08-18-2016, 11:39 PM   #8
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Like the two posters earlier in the thread, I can offer a third recommendation for the Cosworth drop-in filter. I was initially suspect of any benefit, but now I'm a believer - once installed, the engine revved more freely, had noticeably better throttle response, and sounded better, too. Is it a game changer? No, of course not - but it was a nice improvement for less than $50. Easily recommended.
RJasonKlein is offline   Reply With Quote
Old 08-19-2016, 01:23 AM   #9
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Since the difference power wise between those two is so minimal personally I would go with the Perrin because it looks cooler.
tyler_win_photo is offline   Reply With Quote
Old 08-19-2016, 01:25 AM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Any performance drop in filter would do the same exact thing. It would sound nice, rev freely, all butt dynos will be the same.
I went with K&N cause 1. It was $45 at Walmart 2. It's pretty much a midget TRD clone. 3. I have K&N filters on my MR2 Turbo with zero problems over the last 10 years.
But, it really was a coin flip from getting the Apex or other dry filters.
Old 08-19-2016, 02:12 AM   #11
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Apexi nuff said.
https://www.rallysportdirect.com/fit...i-panel-filter
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-19-2016, 02:16 AM   #12
I reckon it doesn't matter ........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (08-19-2016), Manic (08-19-2016), menikmati (08-19-2016)
Old 08-19-2016, 05:21 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
So sitting inside the OEM air box, the Perrin drop in filter looks better than other filters? Do you have X-Ray vision?
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Amputechture (08-19-2016)
Old 08-19-2016, 05:39 AM   #14
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I went with the AFE pro dry S filter, mainly because I'm not a fan of oiled filters on MAF cars, the dry filters have better filtration, and I've had good luck with their products in the past.
-Josh
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JazzleSAURUS (08-19-2016)
Need Help on Replacing Stock Air Filter Sookainian Engine, Exhaust, Transmission 5 03-15-2014 09:47 PM
WTB: Stock air intake filter box BatStig Canada Classifieds 8 08-15-2013 09:09 AM
Perrins new CAI vs Perrin drop in filter. Thoughts? NickFRS Engine, Exhaust, Transmission 76 01-22-2013 12:39 AM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
