Old 08-17-2016, 02:51 PM   #1
prj3ctm4yh3m
Drives: CRV AWD 5MT
Is anyone building with Burns SS mufflers?
They have a pretty sweet repackable two stage muffler.
http://www.burnsstainless.com/2-stage.aspx
Would like to do a single exit 3". was wondering if anyone has already done something similar.
prj3ctm4yh3m is offline   Reply With Quote
Old 08-17-2016, 03:21 PM   #2
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
We have used Burn's mufflers for quite a few custom exhaust systems on other applications they are very nice. I will warn you that they are quite loud. I have not seen them used on the twins yet, but its possible some one has.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
prj3ctm4yh3m (08-17-2016), Sportsguy83 (08-17-2016)
Old 08-17-2016, 03:27 PM   #3
prj3ctm4yh3m
Drives: CRV AWD 5MT
was hoping the two stage would be substantially quieter, but perhaps not then. thanks!
Old 08-17-2016, 03:27 PM   #4
-Phil
Drives: Rb25 neo brz
We are working on something now for my car and the question of using burns came into play. Unless you are going for weight savings a vibrant muffler will sound somewhat similar and will do the job. We are currently working on a full 3 Inch Exhaust with custom axle-back options such as a center exit out of the third brake light. I'll be sure to send you a link when we have a video of it.
-Phil
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
Old 08-17-2016, 03:38 PM   #5
prj3ctm4yh3m
Drives: CRV AWD 5MT
-Phil
keep me in the loop!
The Following User Says Thank You to prj3ctm4yh3m For This Useful Post:
-Phil (08-17-2016)
Old 08-17-2016, 03:40 PM   #6
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I used one! Added to a MAP 3" exhaust.
Originally Posted by kask2_6.0 View Post
Finished my exhaust on Sunday. Actually sounds quite a bit better than I thought it would being NA with a 3" (turbo in the works ) Zero rasp or drone and I think it will easily pass at Laguna. Idle and highway cruising sounds about the same as stock. I have the stock front pipe and an Ace Type-A 350 header.
And wondering why Burns stainless is so expensive? Check out the core versus the magnaflow posted above. Smaller holes and a much higher density meaning more sound being absorbed by the packing material and less packing material leaving the muffler. But inevitably a much higher manufacturing cost.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
Old 08-17-2016, 03:49 PM   #7
prj3ctm4yh3m
Drives: CRV AWD 5MT
beautiful. im in the bay area as well. hope to hear it at some point! the two stage is repackable as well without add'l welding which seems like a nice feature.
Old 08-17-2016, 04:10 PM   #8
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Cool, welcome to check it out. Although, my car will be on jack stands for a bit. Should be a nice added whistle in the exhaust note when she runs again
Yea the two huge benefit of Burns is lightweight and repackable. Not to mention the super high quality. If going turbo I would stick with the single stage but NA or supercharged the 2-stage seems like it would be the way to go. Also, I would stay away from 3" without a turbo. Exhaust note and volume would suffer with minimal power gains (*I think).
Old 08-17-2016, 06:03 PM   #9
ort895
ort895's Avatar
Would love to hear some sound clips if you guys ever get the chance
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 08-18-2016, 09:57 AM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
So is this where Crawford sourced the megaphones for their Gymkhana exhausts?
http://www.burnsstainless.com/megaphone-muffler.aspx
Seems to me a one in, two out using megaphones for tips with a big resonator would look and likely sound pretty awesome.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
WTT: Nameless Axleback with 4" mufflers for 5" mufflers or Perrin (PA/NJ/NY/MD) Pavel Engine, Exhaust, Bolt-Ons 4 10-20-2013 02:53 AM
Building my FR-S Gillams Scion FR-S / Toyota 86 GT86 General Forum 5 09-06-2013 12:37 PM
waiting on my new mufflers!!! wheelman Engine, Exhaust, Transmission 4 09-20-2012 08:31 PM
Burns Stainless Mufflers Captain Snooze AUSTRALIA 5 07-21-2012 08:55 PM
