Old 08-14-2016, 10:24 PM   #1
ismaelgt86
Drives: 2013 scion frs
Why dosent my OFT read my ecu ?
I just got a oft not that long ago and it will not read my ecu i tried it on my friends car works fine i used a new cable it still didn't work ! how do i find out whats wrong like how do i find out if there is a tune on my ecu or how would i update my ecu?
ismaelgt86 is offline   Reply With Quote
Old 08-14-2016, 10:37 PM   #2
humfrz
Welcome to the forum .......
You might try hooking up a code reader to your OBDII port to make sure the port is working .....
humfrz
Old 08-14-2016, 10:50 PM   #3
ismaelgt86
humfrz
The port works fine
Old 08-15-2016, 12:09 AM   #4
humfrz
Originally Posted by ismaelgt86 View Post
The port works fine
OK.
Maybe this reference will help.
http://www.ft86club.com/forums/showthread.php?t=71157
humfrz
Old 08-15-2016, 01:13 AM   #5
Wyattkb
Drives: 2014 Whiteout FRS
Wrong section.
Also it would help if you told us what the error is.
Wyattkb is offline   Reply With Quote
Old 08-15-2016, 06:14 PM   #6
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
is the OFT turning on?
did you buy the OFT used?
was it unmarried before you bought it?
did you blow inside the cable connectors like an old Nintendo game?
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 08-15-2016, 11:56 PM   #7
steve99
The oft can only ever be married to one car at a time
If the oft read icon is grey it means it not unmarried from previous car.
If the read icon is lit up its unmarried and ready to read in and marry up to new car.
OFT will not be able to read in from cars that have a current BRZEDIT or ECUTEK tune in the ecu as those systems change the ecu access codes to lock you out.
you will have to get a tuner with brzedit or ecutek to flash back a stock rom for you before you can marry up an oft or flash with other opensource tools like tactrix/ecuflash
Old 08-17-2016, 02:31 PM   #8
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Talked to the OP. The OFT does communicate with the ECU since it can data display and log. The problem has only to do with ECU reading. So I suspect his ECU has already been flashed (and locked) by the previous owner of the car.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (08-17-2016)
Old 08-17-2016, 05:20 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what options does someone have when this type of thing comes up?
Old 08-17-2016, 09:39 PM   #10
steve99
Unfortunatly its not easy to detect which system has locked ecu , it likey either ecutek or brzedit. In usa i would suggest ecutek is most popular.
All you can do it try to access the ecu with both those systems and see which one can access the ecu, so you either find someone who has brzedit and ecutek and get them to try.
I believe if you buy ecutek system they can unlock brzedit locked ecus, but check with ecutek before purchase, and their may be an additional charge
The other option is replace ecu with a spare unit
Old 08-18-2016, 01:42 PM   #11
Shiv@Openflash
Drives: 2013 FRS
Another thing you can try is to have the dealership flash the ECU back to stock. The success of this depends on if the ECU is only Read protected or both Read and Write protected.
continuecrushing (08-18-2016)
Old 08-18-2016, 04:40 PM   #12
steve99
Unfortunately both ecutek and BRZedit change the ecu read/write seed key access . I don't think you can just change read or write the access to the ecu rom area is controlled by same seed/key access. So if ecu is locked its for both read and write.
So dealer will have no access either.
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Brakes, Suspension, Chassis 2 04-17-2014 01:47 PM
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Exterior Parts (Aero, Lighting, Etc.) 0 04-14-2014 06:48 PM
******* READ THIS NOW! ******* READ THIS NOW! ******* READ THIS NOW! Dave-ROR Mechanical Maintenance and Tools 0 04-14-2014 06:48 PM
This guy dosent like the frs and is....... charged86 Scion FR-S / Toyota 86 GT86 General Forum 60 05-16-2013 09:42 PM
