Old 08-13-2016, 02:11 AM   #1
The_Evil_Scooter
Drives: 2015 WR Pearl Blue BRZ
57Xtreme 18x8.5 +33 offset vs 18x8.5 +42 offset
I'm new to picking out aftermarket wheels and need some advice. From what I have read, the lower +33 offset should give the 57xtreme wheel a more concave look than the +42 offset. However, when I compare images and videos of the 2, it looks like the +42 offset has a more concave look and the +33 looks flatter (very flat). Can anyone clarify this? Which of these 2 will have a more concave look? Thanks.
*8.5 is the max width I am willing to go.
The_Evil_Scooter is offline   Reply With Quote
Old 08-13-2016, 07:51 AM   #2
swarb
I'm not sure about this specific wheel. But in general, if widths are the same, the face is usually the same and the offset difference is the material on the back pad of the wheel where it mounts to the hub. +33 is further out aka wider track than +42, so if they did have difference faces, the +33 would have the more concave face. They probably have the same face and the pics are probably creating an illusion. The concave face on these wheels are on the 9.5 widths I believe, but I am not 100% sure so yeah...
Old 08-13-2016, 08:59 AM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
The +42 is more concave because it's face 2. the +33 is flatter because it's face 1. they're just different designs.
shiumai is offline   Reply With Quote
Old 08-13-2016, 04:20 PM   #4
df.dima
Drives: FR-S and Mazda 3 Sky
19s, but face 2. Looks concave
http://www.ft86club.com/forums/showthread.php?t=68233
There was another topic about 18s I think, consensus was that it is indeed concave and not flat face. Please confirm with a vendor, or the owner.
df.dima is offline   Reply With Quote
Old 08-13-2016, 04:36 PM   #5
RJasonKlein
RJasonKlein's Avatar
If you've narrowed it down to just those two choices, you definitely want the +42 if your looking for a concave look. The 'Face 2' design mimics the look of the 9.5" wheel without the accompanying weight penalty, and was perfect for me because I didn't want to go wider than 8.5", either. Does it look as good as the 9.5" wheel? No, but it's as close as you're going to get at the narrower width. It's a solid choice, so go for it - it's a fitment specifically for our cars, they're strong, and they're hubcentric, too.
RJasonKlein is offline   Reply With Quote
Old 08-13-2016, 04:49 PM   #6
shiumai
shiumai's Avatar
This for sale thread has pics of the 18 x 8.5 +42:
http://www.ft86club.com/forums/showthread.php?t=108764
I took a pic from @Scuba86 thread to show it beside my 18x8.5 +33 front wheels below. the +42 was not available when i purchased mine, or else i'd have ordered that instead. honestly, if they made a 18x9 +40, that'd be the perfect size IMHO. I have 9.5 on the rear.
you can see that the +33 is flatter because the center is recessed. on the +42, it's not recessed as much so the spokes curve inwards more (more concave).
The Following User Says Thank You to shiumai For This Useful Post:
fibble (08-25-2016)
Old 08-13-2016, 08:53 PM   #7
The_Evil_Scooter
Thank you for the side by side comparison pic, seeing the center difference helps out a lot (how recessed the center is for each)
I think I may go with the 42 offset, but I will contact the manufacture to confirm.
Thanks to all who posted with advice.
These rims + 2.5" Perrin cat-back exhaust = a fun car.
Old 08-15-2016, 09:38 AM   #8
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
If you are going for the more concave-ness do the +42. I've seen the +33 and are not as much. I currently have the 19x9.5 +40 ones
Sent from my SAMSUNG-SM-G920A using Tapatalk
Legionsk88 is offline   Reply With Quote
Old 08-19-2016, 12:41 PM   #9
Daver
I have been waiting months for my Face 2's to ship from Japan, supposed to be in soon, will post pics
Daver is offline   Reply With Quote
The Following User Says Thank You to Daver For This Useful Post:
bhmax (08-19-2016)
Rays Gram Lights 57xtreme 18x8.5 33 Offset w/ Tires Continental Contiseal 235/40/18 guitardecadance Wheels and Tires 0 08-21-2015 01:40 AM
RPF1s 18x8, 45 offset samisons Wheels and Tires 18 06-10-2015 05:53 PM
FS: xxr 527 18x8.75 +35 offset gold munjah Canada Classifieds 7 05-13-2014 08:43 PM
Will these fit & not rub? SSR 18x8.5 49+ offset on KW CS coilovers? varun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-01-2014 05:27 PM
18x8 37 offset kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-29-2012 04:29 PM
