Old 08-06-2016, 06:50 PM   #1
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
18x7.5 to 18x8.5 STi Wheel Conversion???
I am curious what everyone's thoughts are...
I just bought a Harrop Supercharger (Boost Yay!)
And it is also time to change my tires and I was thinking since I currently run 18x7.5 et. 48. JDM STi wheels, now would be a good time to consider trading up to 18x8.5 et. 55 for some added traction. Added bonus is that these are the same exact design as my current setup!
All I need are some 15mm 5x100 to 5x114 conversion spacers and I also get perfect fitment.
Thoughts? Worth it for an added inch of traction?
kuczynskika is offline   Reply With Quote
Old 08-06-2016, 06:54 PM   #2
gramicci101
Off Topic
How much would they cost you vs. a similar wheel in 18x8.5 that's 5x100 with a decent offset?
Old 08-06-2016, 06:56 PM   #3
kuczynskika
I paid $1500 to ship my 18" JDM STi wheels from Japan via Japanparts and the seller is offering the 18"x8.5" for $1500 shipped. Same price.
By comparison Enkei Raijuns in the same size would run $900-$1000.
Old 08-06-2016, 07:25 PM   #4
gramicci101
Off Topic
I think I'd go with the Raijins, personally. I like mesh wheels though.
Old 08-06-2016, 10:29 PM   #5
kuczynskika
Fair, but my thinking is that I can maintain my existing JDM look and still add traction. The JDM STi wheels I run now are only available in 18x7.5 for the BRZ and I feel that with the addition of more power I need more traction to effectively put the power down and not have super excessive wheel spin.
Old 08-06-2016, 10:37 PM   #6
gramicci101
Off Topic
If you want to keep the JDM STI look, then I think your idea will be the best way to go. What tires are you running, and what are you planning to run?
Old 08-06-2016, 10:43 PM   #7
kuczynskika
Exactly. The JDM STi look is obviously important to me lol. My current setup is 5x100 225/40/18 et. 48 with Toyo Proxes and the new setup would be 5x114 235/40/18 et 55 with 15mm conversion spacers and Michelin PSS. I just don't know if one inch of tire is worth all the trouble.
Old 08-06-2016, 10:59 PM   #8
gramicci101
Off Topic
On an 8.5 you can run 245/35-18. That might be worth the trouble.
Old 08-06-2016, 11:00 PM   #9
kuczynskika
This may be a dumb question but, how do 245s fit on an 8.5?
Old 08-06-2016, 11:18 PM   #10
gramicci101
Off Topic
They actually fit very well. Here is an example.
The Following User Says Thank You to gramicci101 For This Useful Post:
kuczynskika (08-06-2016)
Old 08-06-2016, 11:19 PM   #11
kuczynskika
Well damn, look at that. Yeah 245s would be perfect for my needs no doubt.
Old 08-06-2016, 11:25 PM   #12
gramicci101
Off Topic
An 8.5 wheel is right in the middle of the recommended range for a 245 tire. 245/35 is the same diameter as OEM. Some people run 245/40, which is an inch taller and has a subtle meaty look to the sidewall.
245/40 R Compounds, which are wider than normal street compounds:
http://www.ft86club.com/forums/showthread.php?t=10091
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
kuczynskika (08-06-2016), Summerwolf (08-08-2016)
Old 08-06-2016, 11:30 PM   #13
kuczynskika
245/40:
This helps alot! I have to say that the 245/35 look is much more appealing to me. I just found a chart which helps explain to me what you have said about the middle of the tire range.
Many many thanks @gramicci101
Old 08-06-2016, 11:34 PM   #14
gramicci101
Off Topic
Also keep in mind that while it may physically fit, it might not work very well. A 245 will fit on a 9.5 wheel, but it'll be very stretched. It'll fit on a 7.5 wheel, but it'll be very pinched. With an 8.5 wheel, you could go from 225 (stretched) to 255 (pinched). A 235 or 245 is ideal for an 8.5 wheel.
Wheel Directory: Work Emotion XT7 18x7.5 +48 / 18x7.5 +42 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-26-2013 09:42 PM
18x7.5 +48/18x8 +43 staggered or 18x8 +43 square? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2013 02:56 PM
Canada: BBS LM 18x9 & 18x8, Kics Conversion adapter SonnyBRZ Wheels and Tires 0 09-28-2012 07:43 AM
Wheel Directory: Work Emotion 11R 18x7.5 +?? / 18x8.5 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-05-2012 12:47 PM
