Old 08-03-2016, 11:05 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
KICS Leggdura 2 piece lugnut.
Does anyone have these?
http://www.ravspec.com/shop/kics-leg...s-with-locking
how do you like them? is it worth it? i need to swap wheels at autocross, would these stand up to the abuse?
slyphen is offline   Reply With Quote
Old 08-04-2016, 07:33 AM   #2
wparsons
wparsons's Avatar
I don't understand the point of them being two pieces? Seems like a waste, and just something to go wrong.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
NyC Zn6 (08-04-2016), Summerwolf (08-04-2016)
Old 08-04-2016, 08:08 AM   #3
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
These look a bit different from 2-piece nuts I have seen before. The ones I have seen, the cone that touches the wheel does not spin and the hex part tightens like normal. This kind of look likes 2 pieces performing the exact same function as a 1 piece, just with an extra part to lose.
Vampyre is offline   Reply With Quote
The Following User Says Thank You to Vampyre For This Useful Post:
wparsons (08-04-2016)
Old 08-04-2016, 08:17 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Looks miserable.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 08-04-2016, 10:34 AM   #5
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Agree.
I think this is a bad design. The only thing I can think of is they are trying to get you to torque down the small black piece so it takes any marring, then you can basically just snug it's shell on.
Some basic Muteki SR48's have a similar look...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-05-2016, 08:52 AM   #6
Ashikabi
Ashikabi's Avatar
Originally Posted by JazzleSAURUS View Post
Agree.
I agree with jazzle. This would solve the problem of lug marring. I've heard of the coating on some Mutekis flaking off right away and my Kics R40s aren't exactly perfect any more but they safe in pretty good shape. They are 2 piece but the second piece is like a washer so you don't mar your wheels. I think these will keep your lugs looking pristine. It's from a respectable brand so if you like the look and want to keep them looking perfect then buy them. If you don't care so much about looks just get Muteki
Old 08-05-2016, 10:21 AM   #7
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
An internal AND an external aluminum hex to strip! wooo!
Brutal idea, seems like they're designed for cosmetics.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 2 Users Say Thank You to Thorpedo For This Useful Post:
JazzleSAURUS (08-05-2016), wparsons (08-05-2016)
Old 08-05-2016, 10:34 AM   #8
JazzleSAURUS
If your car gets trailered from one indoor show to the next, I think it's a fine product.
If you drive your car, change your wheels, be on the actual streets.....skip it.
The chrome mutekis don't flake, the other ones do.
If you care lots about your lug nut finish, you can also do two sets of lugnuts, one for car shows and wrap the leading edge in tape before you put them on.
The Following 3 Users Say Thank You to JazzleSAURUS For This Useful Post:
Mr.ac (08-09-2016), SkAsphalt (08-05-2016), slyphen (08-05-2016)
Old 08-08-2016, 01:37 PM   #9
Yzu
Drives: RS1.0
I have a friend that has those. He keeps the red part off unless he's at shows. Otherwise he just keeps the black steel part on.
Yzu is offline   Reply With Quote
Old 08-08-2016, 09:28 PM   #10
atlbrz
Drives: Hyper Blue BRZ
I have used McGuard two piece lugs for years and never had any issues. I beleive they are similar in design as these.
atlbrz is offline   Reply With Quote
Old 08-08-2016, 10:03 PM   #11
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
I don't see an "internal" hex. I see 2 external hex, but one's a cover for the other.
To me, these seem like a "haha, got ya" for wheel thieves. They'll take the cover off then discover they need a key for the lock. Then they'll throw the covers somewhere and mar your wheels regardless... I don't see a benefit here.
Get the McGards as mentioned above, or the more expensive KICS r40.
sdemo is offline   Reply With Quote
Old 08-08-2016, 11:19 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
These lug nuts seem geared more for show guys, where clean, unmarred lugs would be desirable, as the inner steel lug would take the actual beating.
I would not recommend them for race use. Also, of you are looking to use the 2pc lugs for use with both OEM and aftermarket wheels be careful. The 2pc Kics lugs rotating seat can fail if torqued to the OEM wheels....(personal experience, I damaged all 20pcs.)
The standard Muteki open steel lugs are a great choice and what I currently use.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
slyphen (08-08-2016)
Old 08-08-2016, 11:54 PM   #13
Ashikabi
Ashikabi's Avatar
How did you damage them? The stock wheels use the same bevel/angle as aftermarket wheels
Old 08-09-2016, 03:05 AM   #14
simpleisbest
Senior Citizen
Drives: Scion FR-S
The angle is the same, but the depth of the "seat" on the wheel is not. OEM is a lot more shallow. With the 2pc design of the Kics, the portion of soft rotating seat that didn't make contact with the wheel actually got somewhat flattened.
They were all tightened down to 85lbs.ft
If you are using only aftermarket wheels, they will work fine.
Project Kics Revo Neochrome 3 piece lug DFW Area Swankiest Raven Wheels and Tires 0 02-11-2016 12:47 PM
***EVASIVEMOTORSPORTS LUGNUT SALE*** RAYS,KICS,MUTEKI,BLOX,EVS,WEDS,BUDDYCLUB, Evasive Motorsports Wheels and Tires 10 09-04-2015 07:21 PM
No lugnut inserts acceptable for street use? venturaII Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-02-2015 04:26 PM
Project Kics Leggdura Racing Lugnuts Anthonytpt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-15-2013 06:15 PM
FS: Brand New Project Kics Leggdura Racing Lug Nuts ft86Fan Wheels and Tires 2 09-26-2012 07:05 PM
