Old 08-03-2016, 09:46 PM   #1
MudithJ
Drives: Toyota 86
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT
MudithJ is offline   Reply With Quote
Old 08-03-2016, 11:54 PM   #2
retoocs
I don't think you know what you are getting yourself into. It's not a simple panel swap.
http://www.ft86club.com/forums/showthread.php?t=75265
retoocs is offline   Reply With Quote
Old 08-04-2016, 01:13 AM   #3
wootwoot
Drives: FRS
It would be cheaper and easier to sell your car and buy a new one with climate control.
wootwoot is offline   Reply With Quote
Old 08-04-2016, 10:13 AM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Having done the swap. It not easy at all. Sourcing the Connectors is difficult. You can get them from Toyota, but it is more than the panel is worth ($5 connectors, but the pins with pigtail is $15 each and you need like 30 of these). Finding them from china is an option, but sometime finding the correct pins to use can be a pain. I couldn't find a few of the connectors and had to resort to tapping into the correct wires instead. The entire dash has to come out to do it. If you want true dual climate, you need to get your A/C system drained so you can pull the metal dash bar out to swap out the HVAC case with the correct part number.
DustinS is offline   Reply With Quote
air con, climate control, hvac, retrofit
Changing FR-S AC controls for BRZ AC controls? Ezedge Cosmetic Modification (Interior/Exterior/Lighting) 10 02-01-2016 10:19 AM
Anodized Trim, HVAC Controls, and Battery Tie Downs FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 9 07-29-2015 11:45 AM
Steering wheel controls swap brainstorm KenTK808 Cosmetic Modification (Interior/Exterior/Lighting) 6 06-20-2015 01:13 PM
Tiny amount of engine oil smell passing through aircon? Mim Issues | Warranty | Recalls / TSB 9 01-18-2015 12:11 PM
HVAC and window door switches white LED swap phanguy Interior Parts (Incl. Lighting) 4 04-17-2014 04:58 PM
