Drives: White 2014 Scion FRS
Steering wheel controls swap brainstorm
I have an idea that because Scion uses the same head-unit for the TC,XA, and XB, and those cars come with steering wheel controls. I can somehow get a Subaru Legacy steering wheel to fit our cars, and swap the clock spring over to get the steering wheel controls to work with out head unit. Fingers crossed
![]() So far I have found out that the FRS/BRZ shares the same hub as 05/09+ Subaru Legacy. This is good because that steering wheel is easily available and goes for around $60 on ebay. It has a full range of steering wheel controls, excluding the hands free calling. It also shares the same paddle shift setup as our cars. A negative to this is that the steering wheel is a larger diameter. Here's a picture ![]() The hard part will be getting the clock spring and airbag. I found a set for $300 on Ebay, which is a little pricey. I think I could get it for cheaper at a junkyard. ![]() The steering wheel controls on the headunit are a little tricky too. I got this from a car audio forum. On the back of the H/U there is a 28 pin connector. Looking at the connector from the back of the radio. Bottom row, Pins 20, 21 & 22. These three go to the steering wheel controls. 20 - common 21 SW2 22 SW1 The operation performed is controlled by the amount of resistance connected across the common and one of the SW pins. Here is what I have learned so far. SW1 0 - preset down/ scan up (radio) Next track (bluetooth, CD) 330 - preset up/scan down Previous track (bluetooth, CD) 1.3k - vol up 4.7k - vol down SW2 0 - mode/mute toggle 330- Hang up phone 1.3k - Enter phone menu and step through 4.7k - Pick up phone These values are if multiple switches are set up in parallel to each pin with one resistor per switch. The factory does not use that type of circuit. They build a series ladder so each level adds the previous ones to itself to create the totals listed above, so the factory circuit board has 0, 330, 1.0k, and 3.3k. Your input and help is very appreciated Last edited by KenTK808; 06-19-2015 at 06:59 PM. Reason: progress |
Drives: 10 series FRS
I think the 05 and 09+ Legacy share the same spline as the FRS/BRZ. Atleast that is what the WorksBell site provides.
But the Impreza is different. So I don't know how you fit the WRX steering wheel on the FRS. But if you really did, then i was wrong. and goodjob. |
#3 | |
Sent from my SAMSUNG-SM-G900A using Tapatalk |
This might help
http://www.ft86club.com/forums/showthread.php?t=39244 |
Señor Member
Drives: BRZ SWP
my brz wheel fits in an ae86 so it's the same as that
The Fail Boat
Drives: CWP S.B.
#7 | |
| Redneck steering wheel emblem swap | BuBlake | DIY (Do-It-Yourself) Guides | 50 | 05-06-2020 11:20 AM |
| Steering wheel swap questions | firl21 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-02-2014 08:27 PM |
| Steering wheels have different spline offsets. | robot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2014 09:31 PM |
| AT Steering Wheel Swap | peri.Laynz | Engine, Exhaust, Transmission | 5 | 11-11-2013 08:53 AM |
| Steering wheel spline / Works bell vendor? | NemeGuero | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-16-2012 06:43 PM |
