Old 08-02-2016, 02:47 PM   #1
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
USB audio problems on FRS touchscreen stereo
Hope this helps someone...
I copied about 23 GB of audio files to a USB drive for use in my FRS with the touchscreen stereo unit and was VERY dissatisfied with the results...
The system would "freeze", scrolling was intermittent, ID3 tag data would not be displayed sometimes... When it worked it was great but it didn't work long.
I did some investigation and changed two things that made a world of difference. Now the system no longer freezes, scrolling always works, no more problems with ID3 tags, and startup is near instantaneous. I do not know which of the two changes (or both) were the real fix.
First I found that at some point the MP3 files were on a Macintosh system, and that there were hidden stub files for a resource fork. So if a song file was called "mymusic.mp3" there was also a hidden 4 kilobyte file called "._mymusic.mp3" present for many of the songs. I deleted all of these.
Second I used a utility called "EasyTAG" to fix all the ID3 tags and rewrite them in version 2.4 format.
The takeaway is that if you are having problems with MP3 playback working well on your stock stereo, be aware that it does not do a good job of error recovery if it sees data it does not understand...
Good luck!
nextcar is offline   Reply With Quote
Old 11-19-2016, 05:16 PM   #2
Spoonie_XL
Drives: 2014 Scion FR-S "Monogram Package"
FRS-S Radio not playing MP3s.
That did the trick! Thank you!
Spoonie_XL is offline   Reply With Quote
Zed Amps, Stereo Integrity Subs, Hybrid Audio 3way front stage, Audison Processing AtlasMick Electronics | Audio | NAV | Infotainment 68 12-19-2014 02:07 PM
USB Audio Problems diddyv AUSTRALIA 2 06-04-2014 08:31 AM
Static audio with radio reception? FRS stock stereo encity5 Electronics | Audio | NAV | Infotainment 14 10-02-2013 09:58 PM
audio formats that the stock stereo will play? jstn Electronics | Audio | NAV | Infotainment 5 11-14-2012 10:13 PM
aftermarket touchscreen stereo that scrolls sofrsnsokleen Electronics | Audio | NAV | Infotainment 1 09-25-2012 11:19 AM
