Old 07-30-2016, 08:50 AM   #1
dp1
driving smoother faster
Drives: Sold
Fitting a 2015 engine and trans into a 2014 car - what to look out for?
New build of the 2015 engine I recently bought will be completed by Outfront Motorsports in CA in a couple of weeks and it will be delivered to EFI Logics in CT for installation.
Please advise if you looked into this and are already aware of the changes to the 2015 engine and transmission that should be addressed when they are put into a 2014 Monogram.
For example, apparently the coil pack harnesses are different on a 2015 from a 2014. What else? Thanks
dp1 is offline   Reply With Quote
Old 07-31-2016, 08:40 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You should likely use your old ECU as the new one may not be compatible with the dash cluster, but should run the new engine fine. There are sfa tuning changes between years.
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 03:23 PM
Was looking at this set up. Will i have a problem fitting my 2015 RS1 ?? ChuckButta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-09-2015 01:43 PM
Spyder tail lights fitting in a 2015 or potentially 2016? N3mesis Cosmetic Modification (Interior/Exterior/Lighting) 6 06-16-2015 12:04 AM
STI engine/trans mounts xwd Want-To-Buy Requests 1 03-11-2014 11:00 AM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
