What motor oil to use on a jacksonracing supercharged brz?
Hey guys,
Im pretty much new to this forum but I've been on it for quite a while before I made an account. Needless to say, this is my first post. I currently running the Jackson Racing c38 supercharger on my brz, bigger injectors, pump, flexfuel etc. I was wondering what type of motor oil I should use for oil changes. Some people say, stick to 0w20 while others are telling me to get motul 5w30. I need a tiebreaker xD btw, i live in central california wheres its normally 100+ degrees. please help =( |
[insert cool phrase here]
Drives: BRZ Premium
Well, your hear a bunch of options.
I would hit up Jackson Racing customer service, and ask them what they would recommend. I'm pretty sure that's the best way to go. Other wise everyone and their mother will tell you to put X brand and X weight. I would stick to the factory oil spec till you hear from them. Also FYI Motul isn't all that. Just a different oil brand. Nike vs. Reebok. Which fanboy base do you want to be in? I'm a Mobil 1 fanboy, reason: Walmart cheap, find it anywhere 24/7 7 days a week. Even in the middle of bumfuck vile. Other brands like Motul. Special order, wait a few days a bit pricey. For same exact performance.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
I'd recommend 0w20 Mobile 1.
humfrz |
Drives: 2015 BRZ CWP
I've been running amsoil 5w30 for 6k miles.
Drives: '15 BRZ RA
Your oil will have high temperatures with a supercharger. You will need at least a 5w30 oil. It will be slightly thicker in cold temperatures and provide the necessary protection in high temperatures. Using a 0w20 oil even with an oil cooler is like submitting suicide.
Motul is also a good choice . It is used by STi for many years.
#6 | |
Drives: 2013 Subaru BRZ
edit: central coast for me... i totally glazed over "100+ degrees". I don't have temps that high where I live haha. Last edited by TMW; 07-30-2016 at 02:41 AM. |
Is amsoil 5-30w the best bet with c38, 700cc dw injector, 300cc dw and flex fuel
Legend
Drives: BRZ Limited
I've been boosted for over 30k miles and I've done nothing but Eneos 0w20
#10 |
Fast enough
Drives: 2013 Subaru BRZ AT
Nothing about your motor has changed other than the power output. Oil galleys/clearances/bearings/etc was all designed for 0-20. Use a quality synthetic 0-20.
If your oil temps are staying within range there is absolutely no reason to switch to a heavier oil. |
#11 | |
I hear a lot of talk about this engine being "designed for 0W-20" although Subaru Japan allows thick Euro 0W-30 and 5W-40 in a stock BRZ. http://www.subaru.jp/accessory/engin...miumoil01.html http://www.subaru.jp/accessory/engin...miumoil02.html |
| Tags |
| brz frs supercharged oil |
| RGM Supercharged 86 | GeeTee86 | AFRICA | 63 | 08-16-2015 09:07 AM |
| charged86 supercharged to build motor turbo | charged86 | Member's Car Journals | 9 | 07-24-2015 11:48 PM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
| my supercharged brz | zenny | Member's Car Journals | 17 | 04-29-2014 08:46 AM |
| My Supercharged GTS | Aussie Willy | Member's Car Journals | 23 | 07-12-2013 06:06 PM |
