Drives: 13' BRZ
SPL Rear Camber Arm Question
Installing my Tarmac 2's along with some SPL rear camber arms I picked up used here.
Looks like maybe there were 2 different styles of these arms? One that uses a large nut to tighten against the arm body and one that uses the 3 allen bolts? (as shown in the picture) Mine uses the 3 allen bolts. My question is, the instructions say to measure your factory arm and set the new arm to the same length. It also mentions how far the threads should extend out. I had to extend mine out to the max recommended length to get my arms to stock length. Im concerned about doing an alignment to get more camber but the threads extending out too far. thoughts?
Drives: Man
You are talking about SPL not SPC. when i was installing mine, i was able to get the equivalent length with about 1/3 to half of thread length on both side. not sure why yours can't :/ make sure you are lined up bore to bore and not length to length.
once you figure it out and install, make sure the locking collar has the allen bolt facing down for you to access, or you are going to have a bad time adjusting camber during alignment. |
#3 | |
Drives: 13' BRZ
I guess Ill get it on the rack and see where Im at. |
Drives: Man
The way you were describing the other style of LCA, many mistaken SPL for SPC, as far as i know, there is only 1 style. anyway, put the bolt position together between the SPL and OEM and see if the length is still an issue.
#5 | |
Drives: 13' BRZ
Drives: Man
AutoX-10/10ths every run
Here is how I have mine adjusted.
Drives: 13' BRZ
| The Following User Says Thank You to cruizin01 For This Useful Post: | whataboutbob (07-25-2016) |
#10 |
Drives: Toyota
I had this exact same issue with my SPL LCAs.
I contacted SPL and they send me some longer/beefed up adjusters. |
#11 |
Drives: Toyota
Contact SPL they will send you these longer adjusters.
#12 |
Drives: 13' BRZ
#13 |
Drives: 13' BRZ
Talked to Mike @ SPL today. They recommended just doing my alignment and if Im uncomfortable with the length they can send me the updated ones.
| Spc control arms and negative rear camber question | pbirmingham1988 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 08-20-2016 02:57 PM |
| Rear camber question!! | bamripzit | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 03-10-2016 09:50 AM |
| Rear camber question | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-11-2016 09:35 AM |
| SPC rear camber arm question | Chopstick | Northern California | 6 | 06-10-2014 12:18 AM |
| Rear Camber/Alignment Question | anewprelusion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-26-2013 12:39 AM |
