Old 07-20-2016, 09:17 AM   #1
Duce69
Yes im sure im a T-rex
Duce69's Avatar
Drives: scion - frs
rear end and axles
Morning everyone,
what is the max amount of power a stock rear setup can handle before breaking. does an upgrade need to happen with a slightly modded 2j swap (550hp)?
Duce69 is offline   Reply With Quote
Old 07-20-2016, 10:02 AM   #2
FRS Justin
Drives: 2013 Asphalt FRS
Im pushing 710 with no problem yet. Don't fall for the you need all this crap sales pitch.... I should clarify I run dss axles and a stock diff. I broke axles when I was N/A if that tells you how crappy they are.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-20-2016, 10:21 AM   #3
Ross
Drives: 85 corolla gts
Have a customer currently that has been through a couple of diffs on his low power tune. Stock diff bushings and sub frame bushings could have aided in the issue. We will be modding a sub frame to put a Ford 8.8" in it. Feel stuffing a modular 9" could be less less then cost effective. Car runs 275 rear tires and hooks from second gear on.
Ross is offline   Reply With Quote
Axles D K Engine, Exhaust, Transmission 4 06-27-2016 10:38 AM
DSS Axles? nickmerronesucks Want-To-Buy Requests 6 02-01-2016 08:09 AM
2013 FR-S complete drivetrain: engine, trans, DS, rear, axles, wiring fe Engine, Exhaust, Bolt-Ons 19 03-24-2015 06:03 PM
WTB: DSS 600hp rear axles SterlingBrz Want-To-Buy Requests 1 03-17-2015 08:49 PM
