Old 07-15-2016, 02:45 PM   #1
SirSpectre
Drives: 2013 Hot Lava FRS
Verify my installation of EBC
Hi guys,
I tried searching around but couldn't find any pics on how to install an EBC. So heres a picture to make sure I did it right.
All good?
SirSpectre is offline   Reply With Quote
Old 07-16-2016, 02:08 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
EBCS electronic boost control solenoid
#3 to turbo inlet
#2 to wg
#1 vent to atmostphere
-pigtail to teal harness under backside of uppder intake
Old 07-20-2016, 09:49 AM   #3
nickw14
Drives: Built FA20
That is strange. Port 3 is usually vent to atmosphere...
nickw14 is offline   Reply With Quote
Old 07-20-2016, 09:54 AM   #4
nickw14
Drives: Built FA20
This makes more sense to me for an external wastegate.
Old 07-20-2016, 10:22 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by SirSpectre View Post
Hi guys,
All good?
Follow this image
I had this same question when installing my EBCS two years ago and was on the phone with Grimmspeed about it. They let me know this way in your picture and the way in the picture I posted above works fine. The picture I posted was a newer way to install the EBCS.
The picture you posted is more suited for when you are pushing over 25 psi and need boost help to keep the spring closed and control it better.
Old 07-20-2016, 10:29 AM   #6
nickw14
Drives: Built FA20
Originally Posted by Sportsguy83 View Post
Follow this image
Well that's me... Pushing 25psi lol. I've got a sea of lines and T's too, dual wastegated.
Old 07-20-2016, 01:11 PM   #7
SirSpectre
Plumbing is perfect then. Pretty sure it's the right harness spot too as it is hitting WG pressure. Just have to get it actively v on trolling now
Old 07-20-2016, 02:46 PM   #8
armstrom
Drives: none
you may want to run your "vented" port back to the intake manifold. The way it's configured now you have a small boost leak while the turbo is spooling. Granted, it's a small boost leak, but even a small and intermittent boost leak can be frustrating when tuning.
-Matt
armstrom is offline   Reply With Quote
Old 07-20-2016, 08:47 PM   #9
Sportsguy83
Drives: Limited BRZ
-Matt
The open port does not constitute boost leak (the amount of boost leaking is negligible). Perfectly fine to leave VTA, as per Grimmspeed instructions, running it VTA on my car and having seen numerous setups VTA that port with no issues.
Old 07-20-2016, 09:48 PM   #10
SirSpectre
Got my new tune flashed and Confirmed it is working!
Old 07-21-2016, 11:09 AM   #11
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
After installing mine I noticed a drop in vacuum. Going to have to go through and double check for any leaks. Glad I hooked it up correctly though. Thank you for posting this.
DustinS is offline   Reply With Quote
Old 08-05-2016, 10:04 PM   #12
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Someone have a pic of where port 1 goes?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 08-06-2016, 12:36 AM   #13
SirSpectre
Port 1 goes to nothing. It vents to atmosphere.
Edit: oh hey Wisconsin! I'm in milwaukee. If you're around you can look at my setup or I can help check it out.
Old 08-06-2016, 06:52 PM   #14
sosick
fastest frs in sbg
sosick's Avatar
Yes if u want to come help me tomorrow lol ill be home all day. Ill pay gas n beer. Lol im in Sheboygan
2014 firestorm frs
OEM Oil Cooler Kit and Installation DIY SkiRideDrive Engine, Exhaust, Transmission 80 10-05-2022 08:49 AM
TRD Lip Spoiler Installation (GTA) BG.Ghost8 CANADA 15 05-19-2014 09:44 AM
Need Help with Mic installation on OEM HU mister.bond DIY (Do-It-Yourself) Guides 0 05-11-2014 01:10 PM
KW V3 installation problem BAE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-04-2014 05:09 PM
Installation DIY (FOR YOU) FRSure Mid-Atlantic 11 01-26-2014 06:51 AM
