Old 05-02-2014, 10:48 AM   #1
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
KW V3 installation problem
Maybe someone here knows what is wrong.
In the front I adjusted the coilover height to the middle of the range according to the manual, installed it with HVT camber plates and it came in spot on 35 mm lower. Exactly in the middle of the range as expected. In the rear I set the height to the middle of the range as well, installed the coilover with the factory tops and it came in almost in stock height. Now I have set the coilover to the minimum height according to the instructions and the car is only 20 mm lower than stock. Same at both sides. At this setting it should have been 50 mm lower than stock. Anyone who knows why my car is 30 mm (11/4") too heigh?
For information I have also installed SPC rear control arms, but I can't see how they can influence the height. They are more or less identical to the stocks.
Thanks for input!
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 05-02-2014, 11:04 AM   #2
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Interested to hear about what will cause this also
ExxelDistributions is offline   Reply With Quote
Old 05-02-2014, 12:11 PM   #3
wparsons
wparsons's Avatar
Have you driven the car, or just set it down after installing the rears? Is your ebrake locked?
If you lock the ebrake before raising the car and then set it down after installing the shocks it won't settle all the way down until you release the ebrake.
If you haven't yet, release the brake and roll the car around a bit.
flickr
Old 05-03-2014, 02:22 AM   #4
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I have been driving the car for 2 days afterwards. I have plenty of thread left on the coilover to lower the car to the height I want. But that means going under the minimum height specified for the kit. Any problem with this? Seems like the minimum height is related to the minimum height of the car with lights and stuff.
Again, thanks for input!
Old 05-03-2014, 09:45 AM   #5
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
What tophats did you use in the rear???
Scooby South is offline   Reply With Quote
Old 05-03-2014, 10:03 AM   #6
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I have used the stock tophats in the rear.
Old 05-04-2014, 03:56 AM   #7
Scooby South
Conedancer
Can you take a picture and post it of the rear setup with the wheel off so I can see it
Bill
Old 05-04-2014, 05:09 PM   #8
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
Forgot to take a picture last time I had the wheels off. Anyway, now I have lowered the car 35 mm (1 1/4") in each corner measured from the wheel hub center to the fender edge. The height to the spring fastening ring is not according to KW's paperwork in the rear, but it looks allright. The ring is in the middle of all the threads. Thanks for the interest!
I like KW's so far. Firmer, but still quite comfortable. Now, I can start to play around with the settings for the shocks. Anyone that have found the perfect trackday setting for bump / rebound?
Defi meter installation problem LEMON DIY (Do-It-Yourself) Guides 9 06-25-2016 05:00 PM
Tein Installation Karl07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-13-2014 02:20 PM
NYC Exhaust Installation dad&sonFRS NY / NJ / CT / PA 11 03-29-2014 05:00 AM
Installation DIY (FOR YOU) FRSure Mid-Atlantic 11 01-26-2014 06:51 AM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 02:36 PM
