Old 07-13-2016, 06:03 PM   #1
lee1rbc
lee1rbc's Avatar
Scrub radius
I just put a set of Enkei Fujin wheels on my BRZ 17x7.5 40mm offset. I wanted to set my scrub back to factory so I am using a program from racing aspirations to determine the scrub radius of the BRZ. These are my results.
Factory scrub radius with 48mm offset +20mm or .75 of an inch positive scrub.
With 40mm wheels +28mm or 1.10 inch.
With 225/45/17 1/2 inch taller tire +26mm or 1.00 inch.
http://www.racingaspirations.com/mods/tg7n7uwl
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
lee1rbc is offline   Reply With Quote
Old 07-14-2016, 05:18 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This is one way to increase your scrub radius:
The Following 7 Users Say Thank You to Captain Snooze For This Useful Post:
5H1F7Y (11-20-2018), anytimeparking (07-14-2016), gpvecchi (03-13-2022), Icecreamtruk (11-20-2018), maxjedi (07-14-2016), soundman98 (03-12-2022), wparsons (07-14-2016)
Old 11-20-2018, 12:36 PM   #3
Midnight Cinderella
Mt CR-RRSH
Midnight Cinderella's Avatar
Drives: Black/Metallic Blue
Currently on the same site and doing calcs as well
Is SAI, camber adjustment at the wheel, and offset the only determining factors of scrub radius?
Midnight Cinderella is offline   Reply With Quote
Old 11-20-2018, 01:03 PM   #4
jamal
jamal's Avatar
Drives: Legacy GT
The upright/hub geometry and location of the ball joint are pretty important. Once that is known, then yes sai and offset are the biggest factors that change it.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
wparsons (03-20-2022)
Old 03-12-2022, 09:43 PM   #5
SCFD
Whether or not the 20mm positive scrub OP posted is correct, I assume increasing the scrub by 11mm is a non-issue since many people run on 17x9 +35 wheels. However, what if the wheels I'm looking at will increase scrub by 31mm?
If we assume factory has 20mm scrub, this means I will end up with 51mm positive scrub. Will this be so high that it's detrimental to components or the dynamics of the car?
Also, what if I plan increase negative camber at the knuckle with camber bolts? Will that increase or decrease scrub?
SCFD is offline   Reply With Quote
Old 03-14-2022, 06:16 PM   #6
Grady
Grady's Avatar
Are you changing rim with? If so you will need to calculate that into the equation. Tire width will not change scrub radius since it will add or subtract equally on inside and out.
Old 03-14-2022, 06:44 PM   #7
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Originally Posted by SCFD View Post
...what if I plan increase negative camber at the knuckle with camber bolts? Will that increase or decrease scrub?
Increasing negative camber with camber bolts will increase the scrub radius because it moves the centre of the contact patch outboard.
Changing wheel width doesn't affect scrub radius - only wheel offset, because it moves the centre of the contact patch, which is the critical measurement.
OP - The only way you will get back to the same scrub radius as stock is to use a wheel with stock offset and run stock camber, or increase (positive) camber with a wheel with lower than stock offset.
The effect of scrub radius on handling in a RWD car is much less pronounced than in a FWD car. In FWD, increasing scrub radius increases the lever for drive forces at the wheel to act on the steering, increasing torque steer, etc. Because the steering wheels in a RWD car are not driven, the effects are much less pronounced. You may still get a bit more tramlining and the steering will feel a bit heavier, but it's nowhere near as noticeable or potentially problematic as on a FWD car.
Increased scrub radius *can* change how the wheel bearings and other components are loaded and affect longevity, but the difference is likely minor enough as to be a non-issue within the bounds of what's reasonably possible for changes on our platform, and are most definitely outweighed by things like the improved handling from increasing negative camber, and for some, the visual / aesthetic difference of running a lower offset wheel.
Basically, what I'm saying is, in my opinion, you're overthinking things here...LOL.
Pick lightweight wheels that you like with a reasonable offset (+35mm up to stock +48mm), go with only moderate lowering and keep camber within a reasonable range, and enjoy.
Tatsu333 is offline   Reply With Quote
The Following 3 Users Say Thank You to Tatsu333 For This Useful Post:
Grady (03-15-2022), SCFD (03-14-2022), venturaII (03-25-2022)
Old 03-15-2022, 09:36 PM   #8
Grady
Grady's Avatar
Yes, was not thinking correct above.
How much positive scrub radius until screwing things up? JDM4E Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-08-2015 08:21 PM
Scrub radius help ChrisD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-08-2015 10:14 PM
Decreasing radius corners ZionsWrath Other Vehicles & General Automotive Discussions 48 11-11-2013 07:34 PM
