Old 07-13-2016, 08:36 AM   #1
Rich196
Drives: GT86
HKS Hipermax damaged, can it be repaired? Or replaced
I am based in the UK. On a track day I took a heavy hit on a kerb and my hipermax didnt take it too well. Luckily I could dial out the increased camber and it drove home perfectly.
I have attached a pic, but basically I have bent the threaded portion that goes through the pillow ball. Now a couple of questions:
Has anyone had this happen before?
Can it be fix / straightened or would it be forever weak?
Can I get it rebuilt or just a replacement shock.
Rich196 is offline   Reply With Quote
Old 07-13-2016, 02:44 PM   #2
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
After reading the support section on HKS USA's website, it's likely that they will send the repair out to their Japan facility (between Tokyo and Nagoya). Turnaround time appears to be a couple weeks.
I'd contact the main HKS support and start the process. It's up to you to decide whether to buy a new unit or service the bent one. If this is not your daily driver, I'd let HKS take their time to rebuild the strut to spec. If you need the car ASAP, I'd swap back to stock, thoroughly inspect the nearby components, and get a professional alignment.
Best Guess: They'll replace pillowball cartridge, top nut, upper strut tube, seals, and piston assembly.
If the strut tube is scored on the inside, they'll probably swap the entire damper out. Many aftermarket coilovers use "cartridge" dampers, but I haven't had HKS coilovers before. Since your lower mounts look OK, I'd bet it's cheaper to rebuild than to buy an entire new unit.
Keep us updated, as the repair continues. I'd love to learn about the quality of their customer support.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
Clipdat (07-13-2016), Lynxis (07-13-2016)
Old 07-13-2016, 03:50 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Same here, mine have a few miles on them already so they'll need servicing in the next 2-3 years at the rate I'm going. I'll be keeping an eye on your experiences to determine if I decide to rebuild or get something else when it's time.
Lynxis is offline   Reply With Quote
Worth getting repaired? alexjandro Arizona 10 03-30-2016 05:25 PM
Someone backed into me (repaired with pdr) Estey Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 03-03-2016 11:38 AM
Resell value on a repaired car Vincenttam Southern California 2 04-29-2015 01:26 PM
Car just got repaired - Is this how it's supposed to look? jarviz Scion FR-S / Toyota 86 GT86 General Forum 33 11-26-2014 05:27 PM
Repaired WRB BRZ - Read drewbot Canada Classifieds 25 02-26-2014 11:28 PM
