Old 07-13-2016, 08:10 AM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
JPM Handbrake Boot Install?
Has anyone made a DIY for these? I've searched for one and can't find a step by step guide.
Also, for anyone who has installed one already, what adhesive did you use after peeling the stock handbrake boot off?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 07-13-2016, 10:09 AM   #2
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Not for this car but for others I have owned, E6000 adhesive works well- just let it set overnight.
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
Old 07-13-2016, 10:15 AM   #3
STV3
Señor Member
STV3's Avatar
When I did my BRZ hand brake handle and boot install all I did was rip off the stock one (takes some muscle and twisting but it will give) then unclipped and slid off the stock boot. Slid the new one on, clipped it in and then I believe I just gooped a little bit of crazy glue on the ebrake arm itself and slid the new ebrake handle on (which also takes some muscle to get on).
I honestly don't think I even needed to apply any glue. The left over residue probably would have held it just fine. Unless you drift or something and are constantly yanking up on your ebrake.
STV3 is offline   Reply With Quote
Old 07-13-2016, 02:04 PM   #4
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
3M spray adhesive
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
BFIFE22 (07-13-2016)
Old 07-13-2016, 02:20 PM   #5
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
Originally Posted by Scenic Driver View Post
3M spray adhesive
This is what I used. I didn't get enough on the thinner area of the plastic mounting piece so I had to go back and redo that section as it was coming up a bit. Install is really easy - just pull up from the base of the drivers side of the boot and slide it over the E-brake handle. Carefully peel the crappy fake leather off the plastic mounting piece, clean the plastic well, then spray the adhesive and mount the new boot.
Could've sworn there was a DIY on here, I'll post it up if I can find it.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 07-13-2016, 06:47 PM   #6
acetothermus
Drives: Flying in a Blue Dream
I looked for one a while back and couldn't find it. I'd love to see a really nice one put together though...
acetothermus is offline   Reply With Quote
Old 07-13-2016, 07:24 PM   #7
BFIFE22
BFIFE22's Avatar
3M spray adhesive
Ended up using this. Worked pretty well. Some of the thinner edges are coming up ever so slightly, but shouldn't be hard to go back and touch them up
FS: OEM 2015 FRS Handbrake, Boot, and dash trim staro0989 Interior Parts (Incl. Lighting) 17 01-14-2017 09:44 AM
WTB: BRZ handbrake cover and handbrake boot w/ red stitching 86tylerfrs Want-To-Buy Requests 4 01-20-2015 04:11 PM
How-to: Install JPM Coachworks 6MT Alcantara or Leather Shift Boot JPM Coachworks DIY (Do-It-Yourself) Guides 22 06-26-2014 11:46 PM
Leather Handbrake Boot Repair himbo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-12-2013 12:45 PM
boot lip install problem derka-derka AUSTRALIA 1 09-24-2013 12:10 AM
