Drives: 2013 Scion FRS Asphalt
A plethora of little issues...
Hey guys, I was wondering if any of you all could shine some light on some minor issues I've been experiencing, I am thinking that they are all somewhat interconnected.
1) A while back I noticed that when on the highway at speeds above 65 miles per hour that I begin to experience a decreased steering feel/response. I can literally jerk the wheel a good half inch or so and really not have the car respond at all. 2) This one puzzles me... Occasionally when I am breaking the wheel feels as if it is being pulled to the left of the right (it varies). This does not happen all the time, I'd say it happens once every few days. It only happens when I am trying to come to a complete stop and happens regardless of whether or not it is a quick sudden stop or a gradual one. 3) The steering response seems to be tighter or quicker when turning to the left compared to turning the wheel to the right. I am experiencing this at any speed. Factors possibly contributing to the issue... The car is lowered on eibach sportline springs. Has 18x9.5 + 38 wheels/rims (trying to please everyone). I know the wheel fitment cuts it close but I have always checked for rubbing on my wheels and it doesn't seem to be the case. Also have a aftermarket DCTMS steering wheel but its essentially the stock wheel with carbon fiber that I took off and reinstalled on the car. I should mention that after I reinstalled the wheel it was never perfectly aligned. What do you all think?
Hook Em'
Did you get it aligned after the spring install?
Have you checked the tire pressures? Given the wheel size you are probably running wide tires, which is not going to help with issue #1. |
Drives: 2014 GT86
First thing i'd check tires pressure, and then alignment (if there had been any bigger shocks to car/suspension since times when you hadn't noticed such behaviour).
edit lol, i should have refreshed before posting ![]() P.S. I assumed that after suspension mods you HAD done realignment? If not, highly suggested. Another probability .. maybe you have changed tires to some with soft sidewalls? But given even lower/less flexible sidewall for tires on 18" then on 17" imho that's less probable. |
[insert cool phrase here]
Drives: BRZ Premium
Tire pressure, alginment.
One of your tires maybe 40psi and the other 28psi. Not low enough to trigger the TPS warning light. If that's not the issues it could be odd worn tires. Which is due to alignment
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
I'd say check (in this order) tire pressures, tie rod end play, ball joint play and alignment.
You can check the tie rod ends by jacking up the car and grabbing the tire at 9 and 3, then trying to turn the wheel slightly. Feel for any play where the wheel moves really easily. If both front wheels are in the air you'll be able to move the whole rack left/right, but there will be resistance. You can check the ball joints the same way, but grab at 12 and 6 and try to rock the wheel feeling for play. If you get play on both axis', it could be both parts worn or a bad bearing.
Agree with all the above above
Drives: Raven Black
apparently 3+ = a plethora
Thanks
Also consider it might be in your head? Not every road is a smooth level piece of glass, even if it looks so. I know we love our cars and notice every little thing but it might just be normal.
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Did you get an alignment after your drop? That would 100% be the issue.
#10 |
Drives: Full race 4cyl boxer
There is a sensor that tells the system when the steering is centered.
Perhaps your lowering threw off that sensor and it needs to be reset? And the steering response is supposed to be less when moving at speed as the electric assist may not help you at all above a certain speed. |
#11 |
Drives: 2013 Raven FR-S
#12 |
#13 | |
Even if the assist was the issue, he mentioned that actually turning the wheel isn't giving him the response he's expecting. If it was the assist it would be harder to turn the wheel, but the car would still respond to steering inputs the same as usual.
#14 | ||||
See this thread for a similar issue: http://www.ft86club.com/forums/showthread.php?t=95982 Quote:
| NY WTB; Plethora of parts | mulekr1 | Want-To-Buy Requests | 1 | 12-21-2015 03:52 PM |
| K&N CAI issues. All help welcome | Matty B | Engine, Exhaust, Transmission | 6 | 11-01-2015 04:22 PM |
| Anybody Have Zero Issues? | Don Ivey | Scion FR-S / Toyota 86 GT86 General Forum | 129 | 03-25-2013 01:14 PM |
| more issues after CEL fix.. | DrewZ926 | Issues | Warranty | Recalls / TSB | 2 | 11-07-2012 08:15 PM |
| Anybody with no issues? | tdoggy57 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-04-2012 03:41 PM |
