Old 07-12-2016, 04:24 AM   #1
pr0xy
Drives: '13 WRB BRZ
Unhappy Avo Turbo: Humming / buzzing noise from engine
Hey everyone,
I went my BRZ for a quick ride last weekend and all of a sudden I heard this strange humming noise coming from the engine bay. At first I thought it's the fan, but the fan was not even spinning, so I stopped and checked the engine bay. I have no idea where it's coming from and it does not seem to be connected to revving the engine, it's more of an electrical thing...
When I turn the car off, the humming sound is still there for a second or so and then pitches until it's gone.
Any ideas?
Video:
[ame="https://www.youtube.com/watch?v=xKe9RfZS5K8"]BRZ Avo Turbo: Strange Humming / Buzzing Noise - YouTube[/ame]
pr0xy is offline   Reply With Quote
Old 07-12-2016, 11:15 AM   #2
Lantana frs
Drives: 13 frs red
If it continues after crank stops turning I would look at turbo. Put a screw driver against your ear and listen to different areas of engine bay.
Lantana frs is offline   Reply With Quote
Old 07-12-2016, 11:26 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^ that or vacuum hose in one ear and the other against/near the turbo then have someone shut the car off and see if that's where the noise is coming from after shutting it down.
Old 07-14-2016, 05:29 AM   #4
pr0xy
Drives: '13 WRB BRZ
Case solved - the blow off valve is causing this noise, depending on the heat in the engine bay. It's nothing to worry about, as the valve is still working as it should.
Asked for a replacement anyway, as it's just 3000km old and the boost is so low (~4.5psi) that these issues should not occur in my opinion. Better be safe.
Thank you guys for the replies
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 09:47 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 08:04 PM
Humming noise while driving maylchi Issues | Warranty | Recalls / TSB 9 03-13-2015 01:29 AM
help!! weird humming noise?? sid94 Issues | Warranty | Recalls / TSB 3 05-17-2014 12:16 PM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 10:30 AM
