Smartass
Drives: Toyota GT86 & Impreza STi
Impreza WRX rotors
So I heard in the German FT86 forums somone suggesting to use the 2002 Impreza WRX rotors as an upgrade option. The user stated, that those rotors are proven to be "better" by experience. He mentioned Brembo 09.9077.10 which are in fact the same size than the "original" Brembo 09.A921.14.
Does anyone know what the difference between the two is and why the WRX rotors should be better?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker |
I don't know which year range is applicable, but the WRX rotors are the exact same part as the factory FRS/BRZ/GT86 rotors.
I would ask how they were better by experience... longer wear? There's nothing wrong with the stock rotors, I got over 100k km's on mine with lots of track use.
#3 | ||
Smartass
#4 | ||
Which of the rotors is a newer revision? I would bet the WRX parts are old, and have been replaced across the board by the new FRS part, even for WRX fitment.
| The Following User Says Thank You to wparsons For This Useful Post: | Flasher (07-06-2016) |
#5 | |
Smartass
And that's the FT86 part Dimensionwise the parts look identical except for the gap in the middle. As for the age of the parts - the WRX technical drawing has a more recent date (2014 vs. 2013). Dunno if that is also applicable for the design, or just the drawing.
Junior
Drives: a car
So as wparsons was mentioning, the diagram seems to show the FRS rotors actually having more rotor material to be used than the WRX rotors. The 1.5mm difference is given to the rotor side of the equation, giving the FRS discs a slight thermal edge. Ofcourse this is 2002 WRX brakes.
Smartass
OK I know that bigger rotors are better performing due to the bigger surface, higher heat capacity, and better cooling but does that also apply for rotors with only a weight difference?
I assume that you can put more heat in heavier discs, while the lighter rotors have an advantage in cooling?
Thanks
If they changed it to add more material there must have been a reason. It would have been cheaper to use the existing old part.
Just my opinion.
| Impreza RS 6 spokes. | take the cannoli | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 04-25-2015 09:38 PM |
| FR-S/BRZ VS. Impreza 2.5RS | Alex | FR-S / BRZ vs.... | 9 | 08-27-2012 10:42 AM |
| 3.3 H6 Impreza RS | Starscream15 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 07-10-2012 05:31 PM |
| Why not an Impreza or a WRX? | slizoth | BRZ First-Gen (2012+) — General Topics | 137 | 04-08-2012 12:45 PM |
