Old 07-04-2016, 02:26 AM   #1
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Experience with MooreSport camber plates?
I did a search on the forum but only came up with two threads, both were For Sale threads.
Anyone have any experience with the MooreSport camber plates? When looking around the forum there are lots of usual suspects when it comes to camber plates so I'm familiar with them. But I haven't found anybody posting about their experiences with the MooreSport units. I like the fact that they have discrete adjustments so there is no guesswork and no chance of things getting out of alignment. I'm no expert on camber plates, but I'm guessing a downside is that it doesn't allow for "infinite" adjustment like some of the other "slotted and marked" plates.
I'm not looking to ever get super low with my suspension. Maybe a max of 1" or 1.5" so being able to go low with the camber plates is not an ultimate concern.
Was looking at getting the street version, not their crazy motorsport units.
Street: https://www.rallysportdirect.com/par...t-upper-mounts
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 07-04-2016, 10:11 AM   #2
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
I run these on my car. The adjustments are about 0.5 degree per slot. The only downside is that to get the exact spec you're looking for, you need to adjust camber by using the upper slot in your strut (either slotted or crash bolt) which is more difficult than sliding the strut from the top hat.
infinity21 is offline   Reply With Quote
Old 07-04-2016, 10:36 AM   #3
wparsons
wparsons's Avatar
They also increase the stack height slightly, so if you're not running coilovers you could end up with reverse rake.
flickr
Old 07-23-2017, 08:28 AM   #4
n0thing
Drives: Subaru BRZ
once you had your alignment set, from both top camber plate hole and strut slot/camber bolt, did you ever have to align it again? if so, it'll only be done by adjusting the strut slot/camber bolt?
n0thing is offline   Reply With Quote
Old 07-24-2017, 12:06 AM   #5
redlined600
redlined600's Avatar
Drives: Fr-s
They're probably great if you're camber is equal side to side. Or maybe close enough you don't care. I think the problem is there are enough infinitely adjustable options I'm not sure what problem they are trying to solve.
I like that the plates look nice and thick though.
Old 07-24-2017, 12:51 AM   #6
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Like these?
I got mine with my coilovers (MSI and DMS developed them i believe)
only had them in for 3 weeks now, No issues obviously haha
My suspension guy rated them pretty highly, but I don't do my own alignments, so.. they look pretty!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-24-2017, 01:40 AM   #7
n0thing
Drives: Subaru BRZ
one benefit of having camber plates is being able to adjust from the top without messing with the strut holes. even if you push both knuckles all the way in, its highly unlikely that both will be equal
Old 07-24-2017, 03:22 PM   #8
infinity21
infinity21's Avatar
I ended up switching to Raceseng this season (got them for a good price) so never had the chance to see how much the alignment changed over a track season. Given that I didn't notice any odd tire wear, I assume alignment didn't change much. But the idea would be to do fine tuning through the camber bolt, yes.
Edit: speaking of which, I have my old set for sale if anyone is interested :p
Old 07-24-2017, 06:55 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
n0thing: there is one caveat though to that supposed camplates simplicity. Changing camber also changes toe, and it sometimes it's simpler to adjust camber and toe both simultaneously from below car then camber at topmounts and then crawl back to change toe, even more so if needed to repeat several times.
Old 07-24-2017, 07:57 PM   #10
Cole
Not a troll
Cole's Avatar
But toe changes such a small amount with front camber, it's nearly inconsequential.
Mooresport Camber Plates - Front and Rear Street Canehda Brakes, Suspension, Chassis 1 02-07-2016 07:00 PM
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
Anyone experience a noise that sounds like plates clanging together Frs32907 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-20-2013 09:31 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
