Old 06-30-2016, 11:40 AM   #1
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
Remove dried wax from the fender trim/vent?
I realized I have some dried wax stuck on the fender trim/vent from the last wax I did. What is the best way to remove this? I tried water and a wash mitt; no cigar.
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
Old 06-30-2016, 12:06 PM   #2
Nickosport
Drives: 2015 WRB BRZ Premium
Dish soap/water mix will remove wax. Its safe for paint too, so no worries there.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
The Following User Says Thank You to Nickosport For This Useful Post:
BDKane01 (06-30-2016)
Old 06-30-2016, 01:05 PM   #3
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
If it's stuck in the cracks and details of the vent, a detailing brush should be able to get that right out.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
Old 06-30-2016, 11:46 PM   #4
Tenino
Drives: 13' BRZ
Use some isopropyl alcohol with Q-tips, it will remove/dissolve the wax. Otherwise tooth pick with a steady hand will work as well.
Tenino is offline   Reply With Quote
The Following User Says Thank You to Tenino For This Useful Post:
BDKane01 (07-01-2016)
Old 07-02-2016, 03:02 PM   #5
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Packofcrows is offline   Reply With Quote
The Following 2 Users Say Thank You to Packofcrows For This Useful Post:
anytimeparking (07-13-2016), BDKane01 (07-02-2016)
Old 07-02-2016, 11:21 PM   #6
radroach
Drives: car
Definitely follow with a vinyl and plastic dressing or it will dry out.
Really wax is just as bad as any of these soaps or alcohol at drying out the plastics. To much of this and they'll crumble to pieces.
Old 07-03-2016, 10:55 AM   #7
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Use foam (pads) to get out stuck on wax.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-13-2016, 03:10 AM   #8
BlackCaGuy
Drives: 2013 Scion FR-S Series 10
Try using an pink pencil eraser. It works for me.
BlackCaGuy is offline   Reply With Quote
Old 07-13-2016, 10:34 AM   #9
Jackoblee
Acura Vent Slider
Drives: Red Color with Alloy
Post
Usually, a wax vendor also has a "finish spray" or a between waxings spray. This also is a pretty good way to remove wax.
If your vendor doesn't have that, I'd use a microfiber towel to remove the wax as best you can and use another vendors's finish product. Meguiar's Final Inspection would work fine in this case. Then I'd put 303 on your flairs to seal them and protect them from the sun.
I think you'll find that a slightly damp microfiber cloth is great at cleaning in gereral, doesn't matter if that's extra or old wax.
Jackoblee is offline   Reply With Quote
Old 07-15-2016, 10:37 AM   #10
Amillionoh7
Amillionoh7's Avatar
Drives: 13' Raven FRS n 92 Camaro
+1 use detail spray and a microfiber towel around a credit card. if you use soap or alcohol it will remove any wax it touches so you will ave to reapply wax there.
Amillionoh7 is offline   Reply With Quote
Old 07-15-2016, 10:38 AM   #11
Amillionoh7
if you use a paste wax and have a hard time buffing it off a detail spray will help with that also
Old 07-15-2016, 02:57 PM   #12
ELLSSUU
Drives: FR-S, 951, Venza, Accord, MDX
Peanut Butter or Vegetable Oil and a very soft tooth brush. Seriously.
ELLSSUU is offline   Reply With Quote
Old 07-20-2016, 04:51 AM   #13
wil5bart
Drives: '16 BRZ
Any dish soap can help. The Griot’s Garage Dried-On Wax Remover is intended for that kind of problem and this product is still affordable.
wil5bart is offline   Reply With Quote
Old 08-01-2016, 11:28 AM   #14
supahotfya_86
Drives: Firestorm FR-S
You can use dish soap but if will remove all existing wax on your car. So be sure to add some sort of protection after washing it with dish soap. Use masking tape for the mouldings and edges when waxing. Takes a little more time but rewarding afterwards.
supahotfya_86 is offline   Reply With Quote
How to remove rear seat cushion, quarter panel trim, and B pillar trim zombieite DIY (Do-It-Yourself) Guides 0 03-21-2015 11:32 PM
WTT: my Raven frs fender vent for BRZ fender vent VakaGT Exterior Parts (Aero, Lighting, Etc.) 2 11-13-2014 02:56 AM
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 07:52 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 09:56 PM
how to remove dried polyurethane adhesive derka-derka Cosmetic Modification (Interior/Exterior/Lighting) 2 09-28-2013 02:24 PM
