Old 06-28-2016, 02:40 PM   #1
86 driver
86 driver's Avatar
Drives: 2013 FRS
CELs and not cranking
I just got my engine built and after few days driving, it threw a few CELs. They were C1201, C1237, C1464, C1465, U0100.
On the freeway, I tried to put on the cruise control for a data log. The cruise light was orange and would not engage. It would not crank after it was parked.
I reset the ecu and tried to reflash on ecutek, but no dice. The tune loaded like normal. Ecutek was unable to communicate with ecu.
The shop that built the engine can't figure it out. So now I'm sending it to the dealer in hopes they will find whats wrong. Anybody have any thoughts on it? Hopefully I can fix it in house.
86 driver is offline   Reply With Quote
Old 06-28-2016, 03:05 PM   #2
jwvand02
Drives: 2013 SWP BRZ Limited
Many codes will cause your cruise to not engage.
Sounds to me like one of your ECUs is fried. However it's possible you're dealing with a loose harness or something not grounded properly. I got a couple of codes just by leaving one mounting bolt out of the fuel computer because it uses those bolts to connect to ground.
All of these things definitely could be related to the engine build, but it may be a coincidence. It will be hard to tell, but if it's obvious these things were pulled apart expect the dealership to try to deny any warranty claim.
jwvand02 is offline   Reply With Quote
Old 06-28-2016, 03:15 PM   #3
humfrz
Like mentioned above, I would suspect something (like the ECU) got fried.
I doubt the dealer will have much sympathy and want to put a new ECU in place, at your expense.
no humfrz redneck fixes in this case
Old 06-28-2016, 03:27 PM   #4
Not looking good. Could be just the harness but...
1201
http://share.qclt.com/%E4%B8%B0%E7%9...em/0370016.pdf
1237
http://www.engine-codes.com/c1464.html
1464
http://www.engine-codes.com/c1237.html
1465
http://www.autocodes.com/c1465.html
And the big one U0100
Possible causes
- Faulty Engine Control Module (ECM)
- ECM harness is open or shorted
- ECM circuit poor electrical connection
http://www.engine-codes.com/u0100.html
humfrz (06-28-2016)
Old 06-29-2016, 01:17 AM   #5
steve99
Hmmmm, unlikely all those systems that the cel codes refer to failed at once.
As other said ,i suspect its a pinched/shorted/melted wiring.
Check fuses, if you find blown fuses then look at that circuit to find why it blew in the first place.
If you have built motor im guessing your turbo or SC, check for melted wiring if turbo , o2 sensor wiring is one to check. you probably also have Flex fuel kit check flex system wiring.
Check under bonnet harnesses for pinching wearing on SC belts etc.
Dealer is probably not the best choice,
they charge heaps
they are not familiar with turbo/SC kits on these cars or flex fuel systems or ecutek tunes.
They wont be able to flash ecu even if everything was working as ecutek locks them out. the dealer is likely to get confused with your mods and ecutek tune and start replacing expensive components like ecu.
Best to take it to a specilist subaru shop
humfrz (06-29-2016)
Old 03-27-2017, 06:49 PM   #6
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Wanted to resurrect this. Was a solution found? I don't have any CEL at the moment, but have all these codes found by EcuTek when I do a DTC scan.
Happened after I purchased and had Flexfuel installed - following P1449 code.
SpectreRT is offline   Reply With Quote
Old 09-28-2017, 11:52 AM   #7
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I'm in the same spot - Just happened to notice these as I flashed a new tune.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 09-28-2017, 12:52 PM   #8
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Mine resolved after pulling the negative battery terminal and holding the brake down for a bit to ensure the car totally lost power.
Relearned throttle position - no codes.
- Had to get P1449 disabled in the tune as well.
Old 09-28-2017, 01:08 PM   #9
Gopherboy6956
I didn't see them again when I re-flashed the ECU again a bit later.
cranking noise when steering? dad&sonFRS Issues | Warranty | Recalls / TSB 27 06-10-2019 08:04 PM
Ethanol Vs Gas Cranking Luckrider Software Tuning 2 01-25-2014 08:44 PM
Unichip stock map to avoid CELs pwells Software Tuning 3 12-28-2013 02:57 AM
Engine Mods and CELs Captain Snooze Engine, Exhaust, Transmission 2 04-08-2013 10:13 PM
Cam Gear Related CELs - How many miles? uspspro Issues | Warranty | Recalls / TSB 16 10-22-2012 02:57 PM
