Old 06-27-2016, 10:33 AM   #1
ft86chiver
Drives: penny
Clutch pedal/transmission issue
Hi Everyone!
I seem to be having a weird feeling in my clutch pedal as of late when I shift.
I'ts mostly when re-engaging the clutch after shifting.
As soon as i let go of the pedal and pass the friction point, i feel some sort of friction in the pedal. It seems to coincide with the release of my pressure plate.
Doesn't happen systematically and not on each gear either?
I am about to go have it checked out but wanted to know if anyone had any ideas on what it could be so i can better direct the dealership.
Thanks in advance.
ft86chiver is offline   Reply With Quote
Old 06-27-2016, 10:41 AM   #2
Originally Posted by ft86chiver View Post
Hi Everyone!
Thanks in advance.
Number of things that it could be but the most common known issue for these cars is the throw out bearing. Just get it checked.
Old 06-27-2016, 10:42 AM   #3
ft86chiver
Drives: penny
Thanks!
KCCO
Old 06-27-2016, 04:19 PM   #4
humfrz
While they are under there, you might have them lub the clutch fork.
humfrz
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Clutch Pedal rick s Engine, Exhaust, Transmission 51 09-20-2015 10:08 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
Clutch pedal peeping almost? Gillams Issues | Warranty | Recalls / TSB 3 07-22-2014 02:16 PM
Anyone know how to stiffen the clutch pedal? 86main Engine, Exhaust, Transmission 3 03-01-2014 03:45 AM
