Old 06-25-2016, 03:33 PM   #1
TURBObro10
Drives: `15 WRB BRZ
OFT - Unable to read, ECU in recovery mode??
So I just got my OFT and hooked it up to my 15 BRZ. Initially the screen was blank (white) but after a reconnect it seemed to boot up fine. I'm trying to do the initial read of the ECU but I keep getting the message "unable to read, ECU in recovery mode". Any advice on what is wrong here? I've tried reconnecting it several times, and disconnecting the battery to reset the ECU twice, and yes I pushed the start button twice so it was not just in accessory mode. HELP!?
TURBObro10 is offline   Reply With Quote
Old 06-25-2016, 05:05 PM   #2
TURBObro10
Drives: `15 WRB BRZ
I started the car up and now the CEL is on. Ran the code and its: U0073. I cleared the code (using torque app) and tried to read the ECU again with the OFT, but still the same error. I was thinking the OBD port on my car may be an issue, but it worked fine with my scanner, so maybe its the OFT or the cable?
Old 06-25-2016, 05:57 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
Pretty sure that's a communication error, so you probably have a bad connection at the OBD Ii port. A lot of people have had issues with the OBD pins, they're shitty and they get out of shape when you connect and disconnect a lot. I had the issue myself. I ended up getting an OBD extension cable and keeping it plugged in so I don't continue to put wear on the OBD pins.
Old 06-27-2016, 02:48 AM   #4
steve99
Talk to the oft guys on phone, it may be a oft issue buy more likely the actual oft to obd cable
Old 06-30-2016, 01:09 AM   #5
choiboie
Drives: 2013 Fr-S UltraMarine
Yea I had this issue while back this year. Same error code. Troubleshoot every option. I ended up having a bad cable. Had to send it back in and they sent me a new unit no cost.
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Looking for end of lease FRS/BRZ or theft recovery Four_wheel_drifts Northwest 7 06-27-2016 07:01 PM
New OFT, unable to read ECU peaches Software Tuning 17 05-14-2016 03:46 AM
Disaster Recovery - The Worst Case Scenario UrPast Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 11-11-2015 02:06 PM
Unable to hold idle. CSG Mike Issues | Warranty | Recalls / TSB 22 05-20-2013 06:00 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
